hydro boost? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-24-2013, 07:23 AM Thread Starter
MudWild033's Avatar
hydro boost?
I'm ordering a new power steering reservoir for my 350 and I have the option to order one with or without hydro boost. So how do I confirm if my truck has hydroboost? Thanks.
MudWild033 is offline
post #2 of 4 Old 11-24-2013, 07:56 AM
Powerstroke Techie
If it is a diesel, it has hydra-boost.
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
post #3 of 4 Old 11-24-2013, 08:04 AM
ZMANN's Avatar
Quoted: 1456 Post(s)
the hydro boost uses the power steering pump to boost the brakes vs the power boosters that use vacuum
the new 6.7's ( some /all? ) and others went away from hydro and use a vacuum pump to power the booster I think it was a bad choice myself
so in a nutshel if your power steering lines power the device behind your master you have hydro also you might have the option of tow command master cylinder if your equipped with a brake controller you would want that part
We Miss you Ronnie
ZMANN is offline
post #4 of 4 Old 11-24-2013, 10:04 AM Thread Starter
MudWild033's Avatar
Perfect, that's all I need to know. Thanks guys.
2008 6.4 stroker, Spartan, MBRP 5", S&B cold air, RCD EGR delete
