Puking coolant out the cap - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-24-2013, 05:57 AM Thread Starter
Smile Puking coolant out the cap
Loosing coolant out the cap on puke jug until it gets to the one inch level (almost the bottom of the jug). Fill it up and after 60-70 hwy miles it does the same thing. Pressure test holds just fine kept tester on for almost an hour and no loss of pressure. Oil is perfect no contamination. No white smoke, runs great!
Just seams to be building pressure when driving that causes it to puke out the cap. Put new cap on didn't help.
What defect would cause the system to build to much pressure in the cooling system while driving? I'm no diesel mechanic.
Thanks for any ideas
Mike
Screwdriver 55 is offline
post #2 of 14 Old 11-24-2013, 07:32 AM
kylebryan's Avatar
unfortunately that sounds like a blown head gasket.
2010 F-250 6.4L CC/SB/FX4. Spartan Tuner, 4" Turbo Back Exhaust
kylebryan is offline
post #3 of 14 Old 11-24-2013, 07:42 AM
are you running a hot tune
08 F350 Green/tan
ThcGunSmoke is offline
post #4 of 14 Old 11-24-2013, 09:13 AM
WoodBoy's Avatar
Sounds like a blown headgasket. What model is your truck? I know they swapped coolant level lines sometime during the production of 6.4s. My low level line is actually where the coolant bottle attaches together which is the updated level line. Older ones were high up. I have seen guys who said that their truck would puke when run at the levels on the older bottles, but when dropped to the updated levels they had no puking whatsoever. I am sure this was on WOT runs where it flash boiled the coolant or something, yours sounds a little excessive. I would put a pressure gauge on it while driving and see what you get
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 14 Old 11-24-2013, 05:16 PM
srjd's Avatar
Quoted: 2 Post(s)
I have the old bottle. Mine would puke at the cold fill level. If I lowered it to the updated line it wouldn't puke. My gaskets were still blown. I still keep it at the cold fill line on the old bottle and it doesn't puke now. Looks like your head gadgets are leaking. Especially if you replaced the cap
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #6 of 14 Old 11-27-2013, 10:45 AM
TxBoyJay's 08 KR250's Avatar
+1
mine was overflowing from the cap after running the race tune from sct for about 20mins of driving and flooring it.
W.D.K / South Texas Coal Rollers
2008 f250 CCSB 6.4 King Ranch RoLLn on 35's
Bully Dog CAI
4in Flo-Pro DPF-D TBE 6in Tip
R.C.D Intake elbow / Cold Side IC Pipe *Lime Green*
SCT 3015r Quick Tricks Looney Street Tune "Tnx Vivian"
5k HID's
LED DOME/L.PLATE LIGHTS/LED fog replacement bulbs
30in LED Light bar
Bully Dog Watch Dog Monitor
4in TUFF LED Fogs
Find me
on FB-TxBoy Powerstrokin Martinez
New DD^ 03 GT Vert
TxBoyJay's 08 KR250 is offline
post #7 of 14 Old 11-27-2013, 07:49 PM
srjd's Avatar
Quoted: 2 Post(s)
If its puking on a hot tune and not stock its just stretching the head bolts. Chances are it will start puking eventually on stock
srjd is offline
post #8 of 14 Old 11-29-2013, 05:51 AM
bentstroke_02's Avatar
Yup head gaskets is blown
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #9 of 14 Old 12-01-2013, 07:35 AM
ajordan6337's Avatar
I replaced the cap. Mine does it at cold fill level once in a while but it seems to do fine if i run it just below cold fill level. Does this sound like a headgasket problem?
08 F-250, 6.4, King Ranch, captains, ccsb, 8 inch rough country, 37's on 22' monsters, volant intake, sct livewire innovative tunes, 5 inch turbo back flo pro, top gunz customs control arms, Iron bull
07 Mustang, GT/CS, LT's, Custom 3inch Straight Pipes, 20 inch Razors, Spector
11 F-450, 6.7
ajordan6337 is offline
post #10 of 14 Old 12-01-2013, 11:59 AM
srjd's Avatar
Quoted: 2 Post(s)
More then likely
srjd is offline
