Last top to dealer with warranty remaining... - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-22-2013, 08:46 PM Thread Starter
Tarheel_6.4L's Avatar
I'm right at 99k and the extended warranty I purchased through Ford is about to run out. I'm taking my truck to the dealer for a final list of what I feel should be repaired under warranty. I have a "clunk" in either my transfer case or the front differential after I switch out of 4wd and into 2wd. Also I have a "tapping" somewhere behind my dash. My question to you guys is, is there anything in particular I should have the dealer check? I have an H&S mini maxx that I'll have installed along with a 4" down pipe back exhaust. Most likely the exhaust will be flo-pro. Truck already has an AFE intake.
2008 F-250 CCSB
-H&S Mini Maxx
-4" FLO~PRO
-AFE Stage II
Tarheel_6.4L is offline
post #2 of 4 Old 11-22-2013, 10:43 PM
'086.4LDiEsEl''s Avatar
Quoted: 2 Post(s)
I've had my truck for 200,000+ miles and I hardly had anything happen to it so the issues I had were minimal Than God. But for PM I would have them check the bearing in your front hubs, mine went out around 100k and would make an ugly screetching noise and kept the 4x4 locked which killed my mileage till I replaced it. also my rear hub seal was bad and leaking also around 100k, you should get that checked out while your at the dealer.
'086.4LDiEsEl' is offline
post #3 of 4 Old 11-23-2013, 01:36 PM
Clayton1985's Avatar
The ticking behind dash is the blend door (hvac). The clunking could be normal via the vacuum actuated 4x4....you do have a few miles so its also possible some items have some wear as well.
Edit: Have them check over the cooling system too, updated hoses, rad leak, t stats etc etc.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #4 of 4 Old 11-25-2013, 08:03 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
And pulley tensioners are a common issue I'd have looked at. Mine were replaced at 25k and are still squeaking again at 38k
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
