should I be concerned? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-22-2013, 11:00 AM Thread Starter
Hello all.
I just replaced my air filter with a H&B Cold air intake. When I removed the old filter assembly it was very difficult to remove from the turbo. There was quite a bit of sticky oily substance inside the air tube and at the inlet of the turbo. The truck has 69k miles and has been stock until now. I deleted, tuned and added the CAI. What caused the residue and should I be concerned. Should I attempt to clean the inlet of my turbo? If so with what?
Ladder22 is offline
post #2 of 3 Old 11-22-2013, 11:29 AM
Capt dong's Avatar
Quoted: 5 Post(s)
Normal. That oil is from the crankcase which is why there are tons of crankcase mod threads (ccv). Take a shop towel or rag and spray some brake cleaner on it and wipe off the residue. Check your turbo every now and then. It could be a bad turbo leaking oil but I doubt it.
08 F250 KR
08 F250 XL
Capt dong is offline
post #3 of 3 Old 11-22-2013, 12:34 PM Thread Starter
Thanks!!!!!!!!
Ladder22 is offline
