Dealer Service for next week - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-22-2013, 03:44 AM Thread Starter
Taking the truck in to get the Tensioner/ Idler pulleys replaced as the squeaking noise is becoming more consistent now.
I was also going to have them install the latest flash (trucks a '10 built in '09), fixed cab creaking under driver floorboard and check over a few other odd noises I pick up on every now and then.
I have a stupid blend door (bottom one) that is very intermittent when it comes to the random seeking (HDD/type writer) noise. I'll bring it up too but dont think they will care if it is not doing it when they have it.
Are there any other recommendations you have that I should bring up or look at and add to the list of items I have above?
Thanks much.
2010 HD 48K
DisposableHero is offline
post #2 of 11 Old 11-22-2013, 03:52 AM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
whats the mileage? and do you work truck pretty good or is it kinda mixed work and daily driver?
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 11 Old 11-22-2013, 04:05 AM Thread Starter
48K on the ticker. Dailey Driver 90% of the time and it sees the road 2-3 times a week. I do not tow. I have put on a average of 6k this year.
post #4 of 11 Old 11-22-2013, 04:09 AM
WoodBoy's Avatar
Mine is a '10 doing the exact same things except my creaking is when I drive through a ditch and flex some it sounds like its coming from my rear passenger door area. The blend door that clicks and all is also intermittent on mine and is the lower one. I can put pressure on it while its doing it and it quit. My tensioner/idler only does the squeak/chirp when it gets really cold, but a friend of mine's '10 does it when he cranks up at no matter what
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #5 of 11 Old 11-22-2013, 04:12 AM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
if it were me, I would change these fluids:
1. coolant fluid:
- don't do a chemical flush unless your prepared to replace a clogged oil and or egr cooler, just drain and refill the system with appropriate coolant/distilled water ratio
2. rear differential fluid
- limited slip re-ends require a friction modifier and/or full synthetic fluid
3. transmission fluid:
*transmission flush with a machine is never reccomended don't listen to ford guys...
-just drain the pan, drop pan and replace filters, reinstall pan and refill with appropriate amount and kind of fluid.
all these you can do very easily too.
I do trans, dif, and coolant at 40-60k and oil at 5k and fuel at 10k. granted im a 6.0 but im sure they're not that different from a 6.4
Justin,
post #6 of 11 Old 11-22-2013, 04:15 AM Thread Starter
Any sort of articulation causes it for me including hard right hand turns and hard breaking. I checked sway bar and cab bolt and all looks tight. So I gave up.
post #7 of 11 Old 11-22-2013, 04:17 AM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
Ford sells a grease with some sort of synthetic blend/ fiberglass material in it for joints on the undercarriage. you can ask the parts/ service department to grease everything at your service appointment. it should be a complimentary option.
Justin,
post #8 of 11 Old 11-22-2013, 04:23 AM Thread Starter
1. coolant fluid:
All good points. Thank you.
post #9 of 11 Old 11-22-2013, 04:24 AM Thread Starter
My dealer and I have a good relationship. I would hope I wouldnt have to bring it up but I will so I dont have to deal with it anymore.
post #10 of 11 Old 11-23-2013, 04:15 AM
muntu's Avatar
Justin 0009.....WHY??? is this info that your girl friend's uncle's babysitter told him and passed onto you.
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
