6.4 cold start - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-21-2013, 08:45 AM Thread Starter
CowboyCody's Avatar
6.4 cold start
It was -13* here in western ND this morning. This is the first time I have been in cold weather with my 6.4. It fired right up and started and sounded the same as 20 above. Not plugged in, and strait #2 fuel with stanadyne additive. I have to say I was impressed. My 7.3 would start that cold but would clatter and buck and sit there in a cloud of smoke. The 6.4 was smooth and quiet. Which leads me to the question; how cold will these things start not plugged in?
Originally Posted by madpowerstroke View Post
Try spinning a turbo with compressed air and hit it with diesel clean as you inhale at the turbo outlet, I call it a turbo bong.........that's some good stuff, makes you come up with all kinds of crazy ideas.
2010 F450 Super Duty Lariat Ultimate, 140,xxx Miles. 5" DP Back. Black Maxx. AFE Pro 5R Stage 2. ARP studs new heads and gaskets.
CowboyCody is offline
post #2 of 8 Old 11-21-2013, 12:20 PM
cranked mine over in -25 and it took a second longer then norm but same thing. it will lack some serious power if youdont let it warm up for a bit tho
08 F350 Green/tan
ThcGunSmoke is offline
post #3 of 8 Old 11-25-2013, 08:27 PM
Cranked mine at -35 unplugged (GFI had tripped). Sounded like a tractor for ~15 seconds and then started purring. Glad I have the high idle mod, it would never get warm otherwise!
jerrmy is offline
post #4 of 8 Old 11-25-2013, 09:11 PM
srjd's Avatar
Quoted: 2 Post(s)
-42 is the coldest mine started. Couldn't plug it in that time. I run 0/40 oil it fired right up. Rough for 10 seconds then was fine. Still not good for it I'm sure. Funny this is she fired better then my 6.0 right at freezing
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #5 of 8 Old 11-26-2013, 07:00 AM
Quoted: 45 Post(s)
Last winter it got to 28 degrees one day, and the truck started right up. It was brutal outside.
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #6 of 8 Old 11-26-2013, 08:01 AM
Clayton1985's Avatar
Lol. Wouldn't wanna be in your shoes brother!!
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #7 of 8 Old 11-28-2013, 09:27 PM
theplumbingmedic's Avatar
Boy that sounds like some RUFFSTUFF!!!
2010 F350 lariat cc sb srw
H&S Black Maxx,S&B CAI,,Readylift leveling kit,,GY 325/60/20,Smoked Recon: tail lights,cab lights,3rd brake light and tow mirror lights,AVS smoked window vents,20% window tints,Curt front mount hitch,Rear hitch mounted lights,Sinister coolant filter,PMF dual steering stabilizer,PMF traction bars 51 Gal. Titan tank,Bilstein 5100`s,Rudy`s up pipes,ARP studs,RCD egr delete w/ elbow,AFE cold side pipe,AFE 4"dp, AFE 5"
exhaust
theplumbingmedic is offline
The Following User Says Thank You to theplumbingmedic For This Useful Post:
Tjmaxx (11-29-2013)
post #8 of 8 Old 11-29-2013, 04:18 PM
Mine fired up at -36 celsius which is -33ish after sitting for 2 weeks. Had to wait a bit for the glow plugs to warm up
Trouble maker is offline
