Those with lifted F250's, do me a favor - Ford Powerstroke Diesel Forum
post #1 of 34 Old 11-20-2013, 12:29 PM Thread Starter
I recently had a 4.5 RC lift put on my 08 F250. I run 35's. The front is certainly higher in the front but it sure looks like the front is a 6" raise.
I'm at both sides measured from center tire to push pin in molding center.
Front, tire-to-fender is 12.5"
Rear, tire to fender is 11"
Ground to fender edge front 46.25"
Ground to fender edge rear 45"
if you guys with 6" and maybe some with 4 or 4.5" lifts get me some measurements that would be great.
I don't mind it but it just looks tall to me for a 4.5"
I'm assuming I need some 1" higher blocks in the rear?
shore is offline
post #2 of 34 Old 11-20-2013, 12:45 PM
F250Marine's Avatar
Intrested to see what others say as well I have the same lift sitting in my garage just waiting for the time to install.
2008 F-250 Ext. cab FX4, Spartan tuned 300 EL, S&B intake, 4''DP, 5" flo-pro straight exhaust w/ black 6" MBRP tip.
Coming soon 4.5" Rough Country Lift w/ 18" Ballistic Jesters wrapped in 35X12.5 Nitto Trails
F250Marine is offline
post #3 of 34 Old 11-20-2013, 12:48 PM Thread Starter
I got the boxes they came with the lift but the numbers on the box for the springs correlate to the 6" gas engine F250, which might very well be a 4.5" Diesel spring. I don't know so I ask.
shore is offline
post #4 of 34 Old 11-20-2013, 05:21 PM
Big_Smokey's Avatar
Quoted: 8 Post(s)
Mine is 45". I also have bushwackers and they will measure a little different then no flares. 35" mud grapplers and 4.5" icon
Big_Smokey is offline
post #5 of 34 Old 11-20-2013, 05:24 PM Thread Starter
I have the factory little flares.
This is her.
shore is offline
post #6 of 34 Old 11-20-2013, 05:40 PM
F250Marine's Avatar
The truck looks great man, makes me even more anxious to get mine installed.
post #7 of 34 Old 11-20-2013, 05:41 PM Thread Starter
Thank You.
shore is offline
post #8 of 34 Old 11-21-2013, 04:49 AM
ajordan6337's Avatar
I think its a ford thing. Mine looked off too and rough country sent me a free add a leaf. 6.4 hoods are taller than their beds as well so the slightest difference looks even bigger. If you have a local spring shop have them make you a leaf for the rear its better than any add a leaf you can order. I broke the passengers side add a leaf twice and they made me a much stronger one.
08 F-250, 6.4, King Ranch, captains, ccsb, 8 inch rough country, 37's on 22' monsters, volant intake, sct livewire innovative tunes, 5 inch turbo back flo pro, top gunz customs control arms, Iron bull
07 Mustang, GT/CS, LT's, Custom 3inch Straight Pipes, 20 inch Razors, Spector
11 F-450, 6.7
ajordan6337 is offline
post #9 of 34 Old 11-21-2013, 05:09 AM
Quoted: 3 Post(s)
Or you can change out the block to a F350 block. That will lift your rear up some
11 F250 CCSB King Ranch
Gearhead tunes, No Limit Stage 2, No Limit Block Off, 5" exhaust, CTS
2.5" Carli Commuter, 37x12.5R20 Toyo RTs, Stock wheels
01 Ex 7.3l Limited
Swamps tunes, 6637, 4" exhaust, 6.0 trans cooler, Hellwig rear swaybar, CTS
06 headlights
bigred3297 is offline
post #10 of 34 Old 11-21-2013, 06:07 AM Thread Starter
For some reason I think the block in the rear is a 3"? I guess I need a 4" or is the F350 version for this kit the right size?
I'm also concerned with the carrier bearing, this thing does not have any vibration in its current set-ip with the bearing drop, when accelerating. I certainly don't want to bring that into the mix.
shore is offline
The Following User Says Thank You to shore For This Useful Post:
Big_Smokey (11-21-2013)
