Rear differential... - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-19-2013, 07:52 PM Thread Starter
Dykzeulb's Avatar
Apparently I am a moron. I was attempting to remove the rear aluminum fin cover on my 08 f350, and couldn't get the gasket maker to break free to get it off, I tried a putty knife and a few different blades, but did nothing in terms of getting it loose. I say screw it and I head home, stop for diesel. I get this wild hair that says hey... check your cover..Yep after replacing the bolts its leaking.. If anyone has any tips, that would be awesome.. but nothing I can think of is allowing me to get this off..
2009 Ford F-150 Lariat
Dykzeulb is offline
post #2 of 7 Old 11-19-2013, 07:57 PM
ZMANN's Avatar
Quoted: 1346 Post(s)
it is just RTV sealant so make sure you have all the bolts removed and go around and work it off if a putty knife wont work I use a wedge shape tool ( chisel
it will likely POP all at once and scare you
ps u have new syn fluid and the LS additive if needed ?
We Miss you Ronnie
ZMANN is offline
post #3 of 7 Old 11-19-2013, 08:09 PM Thread Starter
Dykzeulb's Avatar
Indeed, I am prepared with Royal Purple.
Dykzeulb is offline
post #4 of 7 Old 11-20-2013, 09:36 AM
44magnum's Avatar
Ya it's a ***** to get off. You really have to pry on it. I used a gasket scraper and hammer to get under the edge. A putty knife will bend/break long before you break the seal. As said, it's held in place with Rtv not a gasket. There is a groove where you put a bead of Rtv when you put it back together.
2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5 PMF traction
Please collect and message me Shell, Rotella oil cap codes aka "my miles matter" I'm trying to save up for a hat or something.
44magnum is offline
post #5 of 7 Old 11-20-2013, 09:51 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 57 Post(s)
for the love of God, or whatever you hold holy, allow the RTV to cure at least for a few minutes on the CLEAN marrying surface before you bolt her back together..
drewactual is offline
post #6 of 7 Old 11-21-2013, 07:51 AM Thread Starter
Dykzeulb's Avatar
It's done! Thanks guys. Chisel was the way!
Dykzeulb is offline
post #7 of 7 Old 11-21-2013, 07:57 AM
ZMANN's Avatar
I did mine again yesterday there is a nice pry point for the chisel on the axle at about 4: O'Álock
opens it nice and slow to drain
I bet a quadruple amputee could count on one hand how many minutes a real shop lets the RTV cure before they put the cover back on and refill
but if your just tooling around I am sure it won't hurt
We Miss you Ronnie
ZMANN is offline
