Tools... What are they.. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-19-2013, 06:09 AM Thread Starter
What are the tools to remove like heater core hoses and fuel lines?
Looking to add the unique tools needed to be able to work on just about everything on these trucks.
Already purchased socket set for oil and fuel hosing filter replacement. Which work great.
but I know a few I need are:
To remove heater core hoses (hose that connect to the heater core)
Fuel lines
Are there others?
Thanks.
GSchretter is offline
post #2 of 2 Old 11-19-2013, 06:41 AM
Well if you ever have to replace the hard line that runs from the water pump back to the heater core you are going to need a pulley puller and installer to remove the power steering pump pulley because of the 90 degree bend in it and molded flange only other option was remove the entire upper intake manifold. But just so you know you can rent one from advanced for like $40 and when you return it they give you a full refund.
2008 F-350 Lariat TRCCSB Lifted, Tuned, and Deleted
2003 Mach1 Bassani, 4.10s, pro5.0, bama tuned
thnderchcken is offline
