Need help on 2 things? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-18-2013, 02:45 PM Thread Starter
dogrider's Avatar
I have 2 issues going on with my 08.
1st in the last 2-3 weeks my truck is alittle sluggish to start. It used to just crank right up. No hesitation just boom started. Now it's not the same just seems sluggish to start.
2nd when I start it I get a "check brake system" pop up on screen just for a split second and it goes out. I have no codes and if I run system check it all says ok.
Any ideas or help would be great. Thanks Chris
dogrider is offline
post #2 of 12 Old 11-18-2013, 02:54 PM
Check your batteries. Low voltage will cause both issues
Hauser is offline
The Following User Says Thank You to Hauser For This Useful Post:
Lunchbox21984 (11-23-2013)
post #3 of 12 Old 11-18-2013, 02:59 PM
Hunter of Trolls
drewactual's Avatar
Quoted: 66 Post(s)
^bing bing... We has a winner.
drewactual is offline
The Following User Says Thank You to drewactual For This Useful Post:
post #4 of 12 Old 11-18-2013, 06:48 PM Thread Starter
dogrider's Avatar
Thanks for help. I had thought batteries but they are less then 2 yrs old so thought it must b something else. What's best way to test them and what #s on voltage am I looking for. Thanks C
dogrider is offline
post #5 of 12 Old 11-19-2013, 04:41 PM
Without a proper tester, the only way is with a voltmeter. With it running, you should have 13.5+ remove one positive off a battery and check again (not at that battery you disconnected). Connect it, then remove other positive and check again. Shut it off, wait a couple minutes, remove a terminal, check the battery only, should have 12 to 12.5. Connect, remove a terminal off the other battery and check the other battery. Also check voltage while it's cranking. Should be over 10.5. Check while cranking again the next morning to see how the batteries hold their charge.
Hauser is offline
post #6 of 12 Old 11-19-2013, 04:45 PM
Was about to post this exact thing. Good to know.
5in Straight Pipe, H&S Hot Damn all day everyday
nick01 is offline
post #7 of 12 Old 11-19-2013, 04:53 PM
WoodBoy's Avatar
Best is to just run by an auto parts store if you don't have a load tester handy and let them load test the battery. It could be only one battery having a cell go bad
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #8 of 12 Old 11-19-2013, 04:54 PM
is it best to replace both or go one at a time?
nick01 is offline
post #9 of 12 Old 11-19-2013, 06:06 PM
floorboy's Avatar
Do both at the same time.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #10 of 12 Old 11-22-2013, 04:40 AM Thread Starter
dogrider's Avatar
Ok..... Batteries r good. The "check brake system" message is still coming up. It driving me crazy. Also all lights in cab turn on just for a second when I start it. The the message and lights go off. It doesn't do it every time. Seems to be when it's cold or has set for awhile. Will the brake switch show this message if it is going bad?
dogrider is offline
The Following User Says Thank You to dogrider For This Useful Post:
SCTREEGUY (11-23-2013)
