help with coolant issue - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-17-2013, 02:36 PM Thread Starter
my 08 6.4 leaked some coolant today has done it before and just stopped has any one else had this and were do I start?
seeder is offline
post #2 of 12 Old 11-17-2013, 03:53 PM
Wait, it leaked on the ground?
Or just missing?
Missing:
I have this
EGR blocked and disabled
Oil test showed 0 coolant in oil
No longer see white smoke
So where in the heck did it go?
I lost about Pint to 1/2 pint opafter towing to Co...
I with you, where did it go?
Have a BlackStone report just to ensure it's not in the oil
My 2010 has 29K and only run tow tune
GSchretter is offline
post #3 of 12 Old 11-17-2013, 04:55 PM
WoodBoy's Avatar
Did you see that it is leaking down the frame rail or any visible signs of coolant?
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 12 Old 11-17-2013, 08:59 PM
lower rad hose seals
(if you dont allrdy have the updated hoses id do so)
upper rad hose seals
radiator itsself leaking ?
degas bottle puked?
Cap faulty?
Worm clamps on egr coolers not tight and leaking when pressure builds up?
and or the worst cavitation of the front plate / head gaskets
08 F350 Green/tan
ThcGunSmoke is offline
post #5 of 12 Old 11-18-2013, 03:35 AM Thread Starter
ok thanks ill check it out its dripping from prety much right in center like over the tie rods
seeder is offline
post #6 of 12 Old 11-18-2013, 06:31 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Do your upper and lower hoses have the black ends or white?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #7 of 12 Old 11-18-2013, 02:36 PM Thread Starter
black ends
seeder is offline
post #8 of 12 Old 11-18-2013, 02:43 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
It very well could be one of your hoses leaking as the black ends are the old hoses. The new hoses have 2 o rings.
08 F350 cc/sb 4X4
post #9 of 12 Old 11-18-2013, 04:02 PM
have those black ended hoses replaced they are nothing but problems
08 F350 Green/tan
post #10 of 12 Old 11-19-2013, 02:14 AM Thread Starter
ok thanks do you guys by your hoses from ford or after market
seeder is offline
