6.4 engine torque, sensor, fault and wiring info - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-17-2013, 05:28 AM Thread Starter
Hopefully you guys will find this info as handy as I have. This PDF file contains tons of torque specs and patterns for our motors wiring diagrams and sensor breakdowns and some locations. It also has a breakdown of all the fault codes for these engines and what activates them. As well as when the checks for these conditions are performed so if your trying to replicate a situation that caused a fault code this might be your ticket also.
http://www.backglass.org/duncan/ps64...que_Charts.pdf
2008 F-350 Lariat TRCCSB Lifted, Tuned, and Deleted
2003 Mach1 Bassani, 4.10s, pro5.0, bama tuned
thnderchcken is offline
The Following User Says Thank You to thnderchcken For This Useful Post:
96crewcab (01-11-2014)
post #2 of 2 Old 11-18-2013, 10:28 PM Thread Starter
Not sure if this has been posted before or something but just thought this info would be pretty handy to all the DIY guys like myself.
