Engine swap advice :) - Ford Powerstroke Diesel Forum
post #1 of 18 Old 11-16-2013, 09:56 AM Thread Starter
Hi everyone I am new to this forum. I thought I would ask you professionals some advice. So tomorrow I am going to purchase a 2008 F350 that has a 6.4 diesel that is blown up. the truck only has 124000 km now. I have a engine from a f550 that has only 2000 km it is a 2008 6.4 also. It was in a truck that had a slight fire. I plan on putting this motor in the king ranch. So before I go through all this work I figured I should ask here if there is anything I should do to this motor while I have it out of the truck. I know you're all problems with the 6.4's that can be remedied. I'm hoping to have a fairly reliable truck when I am done any help would be appreciated thanks
Cliff717 is offline
post #2 of 18 Old 11-16-2013, 10:06 AM
Capt dong's Avatar
Quoted: 5 Post(s)
studs and egr delete.
figure out why the first engine blew up. It might help in the long run.
depends on where the fire was. fires are probably worse than flooded vehicles.
08 F250 KR
08 F250 XL
Capt dong is offline
post #3 of 18 Old 11-16-2013, 10:30 AM Thread Starter
Ok thanks egr and studs
The owner of the truck says. That the camshaft in the truck is gone. Says they took off the valve cover and says its a mess in there. The engine I have had a small electrical fire in the harness on the lh side under the good. I am going to assume that everything electrical on my engine is scrap. I will use all sensors and electrical off current engine.
Cliff717 is offline
post #4 of 18 Old 11-16-2013, 10:56 AM
bentstroke_02's Avatar
What do you plan on using the truck for? If it was me I would do studs, egr delete, and pushrods.
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #5 of 18 Old 11-16-2013, 12:16 PM
matted2thefloor's Avatar
I would personally do some digging on this swap before turning any wrenches and spending any money as the 350 6.4 and the 550 6.4 are rated differently for power/torque. Whether the rating is the only difference, I'm not sure...but I think there may be some other differences as well.
08 F350 CCLB 4x4 Lariat Job 3
Over 200k on the ticker... Living healthy with the help of some goodies!
matted2thefloor is offline
post #6 of 18 Old 11-16-2013, 12:59 PM Thread Starter
Hmmm I was under the impression tat the long blocks wer the same?
I am going to use he truck for mainly a daily commuter. I will tow sleds in the summer and a 19' boat in the winter but nothing too crazy. As far as the egr delete is concerned. I m from Ontario. Here we have to have emission tests done every two years. Will the egr delete make the emissions worse?
Cliff717 is offline
post #7 of 18 Old 11-18-2013, 07:10 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
If you have the money you could do the international pistons or upgraded HD pistons while the motor is out. Its not unheard of for the factory pistons to crack.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #8 of 18 Old 11-18-2013, 07:19 AM
floorboy's Avatar
Up pipes maybe??
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #9 of 18 Old 11-18-2013, 08:08 AM
egr/dpf delete and an SCT with custom tunes.
That would be the most reliable. What are your plans for the truck?
if you plan on big hp numbers and whatnot, think about studding it and doing 6.0 manifolds and custom uppipes.
Whereabouts in Ontario are you?
SOOTIE is offline
post #10 of 18 Old 11-18-2013, 09:12 PM Thread Starter
I am in dunnville. Near Hamilton. I plan on the truck just being a daily driver. I would like better milage out of it but stock hp is ok with me. Mainly I would like it as reliable as possible
Cliff717 is offline
