Shopping for lift - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-13-2013, 04:17 PM Thread Starter
dieseltruckin's Avatar
Shopping for lift
I'm trying to decide on a lift kit. Max of 4.5 inches, must ride at least as good as stock, must not lose any towing capacity. What are your experiences and what would you recommend? I know that icon and carli will prob be top of the list, but I can't justify spending that much right now.
'08 250 Lariat 4x4 c/c s/b
H&S Mini Max
Cat/dpf delete
S&B Cold Air
dieseltruckin is offline
post #2 of 6 Old 11-14-2013, 07:32 AM
OCVeloMan's Avatar
Quoted: 173 Post(s)
Garage
Finding something to ride "as good as stock" will require you to look to the performance suspension market, not lift kits. I would strongly recommend going with a full spring replacement up font (no spacers) and some IFP designed shocks. I'm pretty sure we're the only ones able to soften the rear while maintaining load capacity as most just use blocks and we use add-a-packs (replace your overload spring).
Regardless, let me know if you do end up having questions on our product and good luck with your build!
OCVeloMan is offline
post #3 of 6 Old 11-14-2013, 08:31 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Pure Performance and Icon both have kits that will ride better than stock.
Pure also can provide a rear mini spring pack to enhance the ride quality.
Or can get you a full replacement rear spring that will ride better than stock but for loads larger than #750 lbs we recommend air bags.
PM me if we can tailor a suspension kit for your needs.
Cary
CT Performance, Inc. is offline
post #4 of 6 Old 11-15-2013, 12:47 PM
I'm looking into the zone kit. The price is very reasonable and comes with everything a quality kit should IMO. I just have not yet met anyone with it on a super duty. I have friends that have it on their 1500 chevy and the ride did not change one bit.
Trouble maker is offline
post #5 of 6 Old 11-15-2013, 01:35 PM
Raul@Stealth Automotive's Avatar
Icon or Carli would be the way to go...
Raul@Stealth Automotive is offline
post #6 of 6 Old 11-15-2013, 02:28 PM
Quoted: 3 Post(s)
Quality and zone?
