Fan clutch quandaries - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-12-2013, 05:59 PM Thread Starter
Alright so my questions is on the 6.4 if the fan clutch is disconnected does it lock up as sort of a fail safe mode or would it free spin. By which I mean spinning with the motor but not keeping up with rpm's. I'm trying to diagnose why since my fan was disconnected it has been stuck on even while disconnected even after idling and driving down the road in multiple situations. It simply refuses to disengage. This all started when I was replacing the heater hose that runs from the water pump to the heater core while doing so I unbolted the fan from the clutch and disconnected the fan clutch connector but that was it. When trouble shooting we did run the motor for a minute or so with out the accessory belt to eliminate other possible suspects maybe this messed up something? Another someone mentioned to me is the bolts from the fan to the clutch aren't installed very tight now if you over torque these may be they could have pinched something inside the clutch? Maybe I'm talking out my butt here I know it's some kind of fluid clutch but not sure on the operation of the clutch if any one has any experience with fan clutches let me know. Normally I would just caugh up the cash and fix what needs to be fixed but up until we changed the heater hose the fan had worked flawlessly before this and now it's decided to show its butt two days before I need to make a cross country trip is kinda aggravating the hell out of me and thanks for your thoughts in advance
2008 F-350 Lariat TRCCSB Lifted, Tuned, and Deleted
2003 Mach1 Bassani, 4.10s, pro5.0, bama tuned
thnderchcken is offline
post #2 of 8 Old 11-12-2013, 06:16 PM
ZMANN's Avatar
Quoted: 1585 Post(s)
what is it doing that makes you think it's screwed up ?
are you getting a code for fan rpm out of range ?
it always has some resistance but they don't purposely fail engaged or disengaged
as far as I know
We Miss you Ronnie
ZMANN is offline
post #3 of 8 Old 11-12-2013, 06:41 PM Thread Starter
Well it's sounds like a jet engine now at just 1500rpm's and I am getting a code for p0528 for fan speed no signal so I'm thinking I may just have a loose connection some where but it just threw me for a loop when I disconnected the fan and the clutch still didn't release
post #4 of 8 Old 11-12-2013, 07:10 PM
ZMANN's Avatar
fun
r u sure that code wasn't stored when you started it without the fan ?
We Miss you Ronnie
ZMANN is offline
post #5 of 8 Old 11-12-2013, 07:25 PM Thread Starter
Yep deleted it about three times now keeps coming back and I have yet to find a wiring diagram showing the fan speed signal wires.
post #6 of 8 Old 11-13-2013, 03:07 AM
StrokiNDieseL's Avatar
Would this help?
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
post #7 of 8 Old 11-13-2013, 04:54 AM Thread Starter
Strokin to the rescue just checked to make sure my signal wire(pin 4) was good and it pulled right out of the connector
post #8 of 8 Old 11-13-2013, 06:03 AM
ZMANN's Avatar
nice,,,,,,,,,,,,,,,,,,,,
We Miss you Ronnie
ZMANN is offline
