2008 possible purchase - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-11-2013, 11:44 AM Thread Starter
New here done some research but mainly find guys wanting to know of reliability with adding more power to these engines. I'm more interested in knowing what problems to look for in a truck. I've found an 08 with 95000 miles, has new wheels and tires and has been deleted. Truck is extended cab short box and has aftermarket exhaust intake and mini max tuner. What problems are typical and how reliable are these rigs if you don't push for extra power?
gerkendave is offline
post #2 of 4 Old 11-11-2013, 01:49 PM
bentstroke_02's Avatar
Well is it job 1 2 3? But with those miles id say the problems the job ones had are already fixed. I have a 08 with 240k on it and up tell now all I have done was belt tensioner. I have to do studs now but if you don't run it hard you wont have that problem.
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
post #3 of 4 Old 11-11-2013, 04:07 PM
how do I find out what Job my truck is? The build plate says 01/08.. I assume that is job1 since its in the beginning of 08. My truck has 69k miles and I haven't had any serious problems. What should I be looking for? Ive owned it for only a year (about 10k miles).
Ladder22 is offline
post #4 of 4 Old 11-11-2013, 04:14 PM
pops250's Avatar
Thats a job 3 if im not mistaken. Mine is a job 1 it was built 2/07. I bought it with 33xxx miles now it has 69xxx , im not after more power either , although it is deleted, but so far i havnt had any major problems just an small oil leak or two.
H&S tuned. B&W gooseneck hitch with Companion 5th wheel. Helwig rear sway bar. Edge CTS monitor. Dieselsite coolant filter. Rancho 9000 shocks. Airlift 5000 air bags with onboard compressor. Viair onboard air with 5 gal tank. Flo-pro stainless 4 in. exhaust.
pops250 is offline
