My rear is sagging... opinions? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-08-2013, 05:06 AM Thread Starter
scotiadallas's Avatar
Hi All,
I routinely tow a 24' enclosed trailer loaded to about 9000lbs.
In side the bed (with cap) I put 3 dirtbikes and gear (1000lbs).
The rear end of my truck sags and I am tired of it.
I've installed a weigh distribution hitch and any sway, and this certainly helps but it's still not level. I was thinking of air suspension or airbags for the rear but I'm not sure.
Can anyone suggest a fix?
D
scotiadallas is offline
post #2 of 10 Old 11-08-2013, 05:09 AM
juniorssrollin's Avatar
Quoted: 2 Post(s)
A set of bags would be your best bet since it won't effect the ride at all times. I have bags and have filled my bed with fill dirt, think it was like 3 cubic yards, it was up to middle of rear windows and the truck didn't even squat more than a inch with 45-50 PSI in the bags
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
post #3 of 10 Old 11-08-2013, 05:20 AM
Heavy_GD's Avatar
Quoted: 1496 Post(s)
Feedback Score: 3 reviews
Same here. Air all the way.
You can get a legit bag set up
1999-2004 Ford F250, F350 2wd 4wd - Firestone "Ride-Rite" Air Bag Helper Springs
or buy air shocks, same effect
GD
Heavy_GD is offline
post #4 of 10 Old 11-08-2013, 05:21 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
We run the Firestone air bags at work and we beat the death out of them on a daily basis. Have yet to have one fail.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 10 Old 11-08-2013, 05:27 AM
luke7.3's Avatar
Quoted: 24 Post(s)
I've got a 94 f250 on here for sale that has a set of air bags. Check out the pictures here http://www.powerstroke.org/forum/tru...n-350-4x4.html . It was a $400 system but $200 and you got em
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #6 of 10 Old 11-08-2013, 06:01 AM Thread Starter
Love this idea fellas. I suspected that was the solution but it really helps to get a second opinion.
I'm guessing I can install the bags myself - I got a 2008 250 4x4 PSD.
D
post #7 of 10 Old 11-08-2013, 06:33 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Is your truck a f250 or f350. If it's a f250, getting f350 leaf sorus in the rear may help but will prolly effect ride when your empty. Air bags will prolly be an easy solution and very little change in ride because I think you have to have Atleast 5psi in them is what I read somewhere. But I could be wrong.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #8 of 10 Old 11-08-2013, 06:37 AM Thread Starter
Anyone know a good place to order the Firestone kit?
post #9 of 10 Old 11-09-2013, 02:28 AM
muntu's Avatar
check out timbrens....no air needed.....and less expensive.... I had airbags on my 7.3 and the adjust pressure was a nice feature but timbrens are install and forget.
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #10 of 10 Old 11-09-2013, 07:14 AM
08forddr's Avatar
Go with air bags. They are easy to install I did it in my driveway with basic hand tool. The time consuming part is running the air lines. If you do an on board compressor, I mounted mine on the fuel tank sheild. Once again running the air lines and wires are the time consuming part. I used the firestone bags that mount inside of the springs.
2008 CC Lariat short bed
35x12.5x20 XD Hoss , Leveled
Sct tuned by IDP , Air bags
08forddr is offline
