Anyone familiar with ford IDS software? - Ford Powerstroke Diesel Forum
post #1 of 23 Old 11-06-2013, 05:45 PM Thread Starter
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Had my buddy stop over from ford to try to turn the lamp outage feature off so I can run LEDs without having to splice in resistors to get rid of the fast flash. We used the sequence I attached below. I returned my truck to stock before we did all this.
Anyone done this before? We clicked turn lamp outage off and the blinkers still flash fast like a bulb is out. Are we doing something wrong? He has never done it before so he isn't sure. And does the truck have to be returned to stock to try this again?
Sorry for all the questions but I spent all this money on led's I just want them to work right haha.
Thanks for your helpAnyone familiar with ford IDS software?-imageuploadedbyag-free1383791798.918530.jpg
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #2 of 23 Old 11-08-2013, 07:08 PM Thread Starter
travisH3's Avatar
Quoted: 2 Post(s)
No one?!?!?
T-rav
2010 F350 6.4-
travisH3 is offline
post #3 of 23 Old 11-17-2013, 07:16 AM
Powerstroke Techie
First: Module reprogramming menu.
GEM/SJB - make sure the GEM/SJB is at the latest calibration level. Update if required.
THEN:
Module Reprogramming Menu
Programmable Parameters
Exterior Lighting, click the Tick in the lower right of the screen.
Click the tick on the popup box.
Click Stop and Taillamp Outage Configuration
Select Lamp Outage Turned Off.
Click the tick in the bottom left of the screen.
That should reprogram it.
https://www.fleet.ford.com/truckbbas...ml/Q-158R1.pdf
Ford Senior Diesel Technician
2008 F-350 4x4 Off Road 6.4 Powerstroke Diesel
There are strange things done 'neath the midnight sun by the men who moil for gold.
The arctic trails have their secret tales that would make your blood run cold.
Big Angry Hillbilly is offline
The Following User Says Thank You to Big Angry Hillbilly For This Useful Post:
travisH3 (11-17-2013)
post #4 of 23 Old 11-17-2013, 07:17 AM
Powerstroke Techie
And it may have to be stock to do this. A friend of mine tried to do an alternator change up on his truck and it wouldn't take the programming until returned to stock.
post #5 of 23 Old 11-17-2013, 07:36 AM Thread Starter
travisH3's Avatar
Quoted: 2 Post(s)
Thanks for your help. I think what we didn't do was clicking the "tick" at the bottom left to reprogram it.
T-rav
2010 F350 6.4-
travisH3 is offline
post #6 of 23 Old 11-17-2013, 08:07 AM
Powerstroke Techie
Try it, if it gives you an error message return it to stock. I had problems turning off TBC on my buddy's truck the other day and it's tuned.
post #7 of 23 Old 11-17-2013, 08:40 AM Thread Starter
travisH3's Avatar
Quoted: 2 Post(s)
I'd be scared to screw something up without returning it to stock. I sent him your steps and that's what we did but I don't remember him pressing the ticks. He said we exited out of personality and went back in and double checked it was set to lamp outage off and he did the key off and back on thing which saves it. He claims he has done it to cab and chassis trucks just fine but for some reason my truck didn't take it. I spent all this money on LEDs expecting it to be easy for him to turn the option off and so far it's been a pain in the neck. Thanks for your help though, I really appreciate your efforts.
T-rav
2010 F350 6.4-
travisH3 is offline
post #8 of 23 Old 11-17-2013, 08:51 AM
Powerstroke Techie
That's really weird.
Make sure the GEM/SJB is at the latest level first, I've done it on lots of trucks as well never had an issue.
Only other thing I can think of is - did you do a TPMS delete with H&S? This also modifies modules in a way that might freak the IDS out.
Once my wife gets home I will swing out to my pickup and see if I can turn it on/off via the way I told you.
post #9 of 23 Old 11-17-2013, 08:54 AM Thread Starter
travisH3's Avatar
Quoted: 2 Post(s)
Your good! Yes I have my tpms turned off. Is there anything I can do or does that not allow you to adjust modules anymore. Because even after returning to stock the tpms never comes back on.
T-rav
2010 F350 6.4-
travisH3 is offline
post #10 of 23 Old 11-17-2013, 09:06 AM
Powerstroke Techie
I believe you can turn TPMS back on with the H&S.
It MAY be screwing up the IDS because the way H&S turns TPMS off does not COMPLETELY turn the TPMS off in all the modules. If you notice, the TPMS lamp still proves out when you cycle the key.
Like I said, I don't know for sure, but I would go back to stock stock stock on everything before trying it.
I just pulled up a previous session on IDS of my buddy's truck, and the TPMS is turned off via H&S. I can pull up the TPMS pressure setting menu in programmable options, but both front and rear are showed as 38psi. So I'm not sure if you just program the pressures back in using IDS or you have to restore the asbuilt data.
Basically, the way I see it right now is IDS may not see the module as fully configured if the TPMS is showed at 38psi on front and rear.
This is just speculation at this point, however.
