winter grill cover install? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-06-2013, 12:11 PM Thread Starter
Hello my 08 came with a ford front grill cover when I bought it but they didn't have the installation instructions. Does any body have a copy they can scan and send me? I'm not quite sure how this thing goes on.
pointman7881 is offline
post #2 of 7 Old 11-08-2013, 08:09 AM
Alberta Advantage's Avatar
Quoted: 19 Post(s)
The instruction Ford includes with the winter front are hard to decipher/useless. Here's some pictures of how I install mine. I've had no issues with it and I've been running the cover every winter, weather permitting. I'll put it on and take it off several times during the winter depending on the temperature.
1. Put the four brackets with the Velcro on the edge of the grille where the side tabs for the winterfront are. There's two tabs per side.
2. Feed the straps through the grille and secure them to the holes on the grille. Tighten the straps up.
3. Bend the bottom tabs at a 90* angle.
4. Close hood.
09 F350 CCSB SRW Cabela's.
Husky Weather Beaters
Putco Window Visors
Piaa Xtreme White 4k
Dura Flap SS Mud Flaps
Recon Smoked Mirror, Brake, Tails
Line-X
Bak Flip F1
BDS/Fox 2.0 Dual Steering Stabilizer
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
12" XMitter Low Pro Prime
4" Solstice Prime
20" Evo Prime Double Stack
12" XMitter Prime Ambers
Truck Bed Lights
Alberta Advantage is offline
The Following User Says Thank You to Alberta Advantage For This Useful Post:
GSchretter (11-26-2013)
post #3 of 7 Old 11-08-2013, 09:35 AM
srjd's Avatar
Quoted: 2 Post(s)
I just bought one and looked at the instruction I'm pretty sure the same guy who makes ikeas instructions makes these as well. I hope those 4 Velcro tabs don't rub the paint off. I think I might put the straps like you have them. I have them strapped to the holes under the hood. I can't believe how well this thing works.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 7 Old 11-08-2013, 09:47 AM
Quoted: 19 Post(s)
I've had no issues with the Velcro pads rubbing paint off. They seem to be protected on the inside. Also, where they attach, is where the grille meets the headlight so you can't really see anything if they do scratch some paint off but better safe than sorry.
Putco Window Visors
Line-X
Bak Flip F1
Fox 2.0 shocks
Good Year Duratracs
Firestone Air Bags
Air Horn
MiniMaxx/5" TBE
No Limit EGR Delete
Vision X Lights
2" Solstice Solo
8" Evo Prime
4" Solstice Prime
Truck Bed Lights
post #5 of 7 Old 11-08-2013, 11:04 AM
08PowerstrokeFX4's Avatar
I could use a new one...does anyone have a part number for this?
F250 CCSB 6.4L Powerstroke
Spartan Tuned, ATS Trans, Sinister Diesel Goodies, Elite Diesel Goodies, and a bunch under the hood.
We miss you Ron. Thanks for everything you did for us and sharing your knowledge!
08PowerstrokeFX4 is offline
post #6 of 7 Old 11-10-2013, 04:03 AM Thread Starter
Thanks for the pictures they should help me figure it out.
post #7 of 7 Old 11-25-2013, 08:43 PM
Well, mine's installed but not the way your pics describe Didn't help that it was below zero and there was ice all over my hood. It stayed on when I drove to work today
jerrmy is offline
