Broken Headlight Adjuster - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-05-2013, 07:16 PM Thread Starter
brendanlush's Avatar
Hey guys.
I was adjusting my headlight this past weekend and I must have turned the hex screw too much and it snapped off in my 5/32 driver. Is there anyway to manually adjust the headlamps?
I replaced my old HID's with a set of DDMTuning and the driver side beam was way too low.
Any help would be appreciated!
I also asked in the body section but with no avail, hopefully someone can chime in!
Sent from AutoGuide.com App
2008 F350 FX4 RED(every option)
3" Rough Country Lift
35x12.50x20 Cooper Discoverer STT TEK3
S&B Cold Air Intake
SCT Livewire Extreme (RCD 450 Tune/IDP Xtreme Street)
FLO~Pro DPF/CAT Delete Pipe
Ballistic Jester 20x9 8x170 +12BS(black/red)
N-Fab Nerf Bars(black)
2011 FX4 Stickers(black)
2011 Arctic Cat M8 Sno-Pro
SNO-STUFF Silencer Can
brendanlush is offline
post #2 of 3 Old 11-05-2013, 07:39 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Not sure where it broke off at but maybe you can get to nuts threaded on it so you can turn the nuts themselves.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 3 Old 11-05-2013, 07:59 PM Thread Starter
The screws broke off flush with the plastic. I am going to try and grind a bit of the plastic away to see if I can't et enough of the screw to adjust them again.
S&B Cold Air Intake
