6.4L clockspring removal & installation - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 17 Old 10-30-2013, 08:35 PM Thread Starter
My cruise and stereo controls quit working on my steering wheel the other day, then no horn and then the airbag light came on. The clock spring obviously wasn't transferring a signal or had a broken connection. Time to change it out. Thought I would snap a few shots since I couldn't find much info about changing it when I was looking for it.
step 1 remove tilt lever.
step 2 remove 3 screws holding plastic upper/lower column covers in place
step 3 pull on plastic dash panel and remove it
step 4 remove upper and lower column pieces
ID:	189721   Click image for larger version
ID:	189729   Click image for larger version
ID:	189737   Click image for larger version
merculous is offline
The Following 3 Users Say Thank You to merculous For This Useful Post:
Fun.250 (04-04-2017), raceit17 (03-19-2015), rdcox23 (04-23-2015)
post #2 of 17 Old 10-30-2013, 08:41 PM Thread Starter
step 5 turn steering wheel to the left into the 9 o'clock position.
step 6 remove number 32 fuse, which is (red 10amp) to kill the air bag module (in passenger side floor kick panel)
step 7 remove the ground cables from both batteries (diesel truck) using a 8mm socket
ID:	189777   Click image for larger version
ID:	189785   Click image for larger version
The Following User Says Thank You to merculous For This Useful Post:
post #3 of 17 Old 10-30-2013, 08:50 PM Thread Starter
step 8 with the steering wheel in the 9 o'clock position, use a screwdriver and release the 3 retaining clips holding the airbag in place, these are on the back side of the steering wheel, push these clips inwards towards the center of the column to release them, use a mirror or a shiny lighter to view clips.(see photo)
step 9 lift airbag out of steering wheel, unclip the 2 wiring connectors (airbag & horn) from the back of airbag and fully remove it for now, point it away from yourself when carrying it (see photo for 3 retaining clips on rear of airbag)
ID:	189801   Click image for larger version
post #4 of 17 Old 10-30-2013, 09:01 PM Thread Starter
step 10 rotate the steering wheel back to the 12 o'clock position and remove the center bolt with T-50 torx socket. Remove steering wheel by pulling outwards (no puller required). remove the clock spring by removing the two T-20 torx head screws.
step 11 install new clock spring and re-install steering wheel, its now okay to pull out and remove the yellow alignment ripcord.
ID:	189817   Click image for larger version
ID:	189825   Click image for larger version
post #5 of 17 Old 10-30-2013, 09:09 PM Thread Starter
step 12 plug wiring connectors back in and re-install airbag by simply pushing inward firmly until all three retaining clips snap back into place and catch.
step 13 re-install plastic covers, tilt lever, re-install 10a fuse in lower passenger side kick panel, re-connect battery cables.
step 14 Your all done!!!! go relax and enjoy yourself with a beverage.
rmfoster99 likes this.
post #6 of 17 Old 10-30-2013, 10:02 PM
floorboy's Avatar
Great write up.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #7 of 17 Old 10-31-2013, 06:10 AM
rt_hawk's Avatar
Thank you for this! Very nicely done...
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
post #8 of 17 Old 08-16-2014, 08:15 PM
groove's Avatar
I know this is an old thread but having same issues and thought this could use a bump! First cruise went, then horn and now airbag light.
Great article, thx!
08 F350 CCSB 4x4 01/07 Job 1
0.030" de-lipped slugs, 70+ atmosphere turbo, ARP studs, Mild Ported Heads (w/bronze guides), Flo-Pro EGR Delete
Mini Maxx Race tuner, AFE exhaust turbo back, S&B Intake, Sinister coolant filter
Lifted nicely on 20" wheels
groove is offline
post #9 of 17 Old 08-17-2014, 05:08 AM
Slacker
Evil Eye's Avatar
Quoted: 233 Post(s)
Feedback Score: 4 reviews
Thread has been made a sticky to make it easier for others to find. Great write up!
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #10 of 17 Old 08-17-2014, 11:46 AM
Fueling M.A.D. Everywhere
CountryAggie's Avatar
Awesome. I need to do this still...
-Tyler
Texas A&M c/o 2010
CountryAggie is offline
