p0196 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-30-2013, 08:22 AM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
p0196
Got this code this morning and a check engine light I think its for engine oil temp being too far apart from coolant. Could it be cause the truck was plugged in coolant was at 118. Oil was much cooler. Once warmed up my deltas were the regular 5 degrees apart.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #2 of 3 Old 10-30-2013, 06:53 PM
matted2thefloor's Avatar
P0196-EOT sensor circuit range performance.
20 minutes of engine run time and EOT has not changed more than 5 degrees C.
Possible areas of concern: wiring, ECT sensor or PCM
08 F350 CCLB 4x4 Lariat Job 3
Over 200k on the ticker... Living healthy with the help of some goodies!
matted2thefloor is offline
post #3 of 3 Old 10-31-2013, 07:09 AM Thread Starter
srjd's Avatar
Quoted: 2 Post(s)
Strange. Seems to be fine now
srjd is offline
