New style key for an 08 - Ford Powerstroke Diesel Forum
post #1 of 105 Old 10-28-2013, 03:04 PM Thread Starter
Don't you worry about it
strokinpower's Avatar
Quoted: 278 Post(s)
Just in case anybody was wondering, I have been wanting the newer key with the fob built onto it to save some pocket space. I went on ebay and ordered this key New Ford 80bit Keyless Entry Key Remote Combo Fob Replacement Uncut 3 Button | eBay
When the key arrived I took it to my work and cut it myself. To program the key you HAVE TO HAVE 2 KEYS THAT ARE ALREADY PROGRAMMED AND WORK ON THE TRUCK. To program the key you insert your first already programmed key and turn the truck to the run position without cranking it then remove that key and insert the second already programmed key and do the same thing then take the new un-programmed key and do the same thing with it and that will program it. To program the remote feature gather all the remotes you have that you want programmed to the truck and insert any programmed key and cycle the ignition from off to run 8 times ending in the run position. The locks should lock and unlock, when this happens you need to press the lock button on all the remotes you want programmed. Once you have done that turn the key to the off position and it should lock and unlock again completing the programming.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #2 of 105 Old 10-28-2013, 03:56 PM
floorboy's Avatar
Thanks I just bought one..... The factory keys have a chip in them??
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #3 of 105 Old 10-28-2013, 03:58 PM Thread Starter
Quoted: 278 Post(s)
Yes they do.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #4 of 105 Old 10-28-2013, 04:07 PM
matted2thefloor's Avatar
Awesome! I've been wondering about this for a while... Putting this on the to do list after the cluster gets replaced!
Thanks for sharing!!!
08 F350 CCLB 4x4 Lariat Job 3
Over 200k on the ticker... Living healthy with the help of some goodies!
matted2thefloor is offline
post #5 of 105 Old 10-28-2013, 04:09 PM Thread Starter
Quoted: 278 Post(s)
No problem!
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #6 of 105 Old 10-28-2013, 04:26 PM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
I am wanting to do this. this is awesome I never knew you could do this yourself, thought it took a dealer or locksmith with the proper computer hook up to do it.
sux I only got 1 key and 2 fobs with my truck so I guess im still stuck going to the locksmith to have them cut/program a key and fob.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #7 of 105 Old 10-28-2013, 04:34 PM Thread Starter
Quoted: 278 Post(s)
Yea, I feel your pain. When I bought my truck it only came with one key. I ordered another regular key off ebay for $9 when I bought the truck and had the dealership cut and program it for $50 IIRC. I asked my buddy (Ford Service Writer) the other day how much it would cost me if I went to the dealership to get this key and he said $225. So you are still coming out WAY ahead. Also you can program the fob even with just one key. You only have to have two programmed keys to program another key and you can have up to 8 keys at a time programmed to one truck.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #8 of 105 Old 10-28-2013, 04:56 PM
Quoted: 4 Post(s)
we have a really good locksmith place right around the corner from our shop and I talked to them about doing this exact same thing you did with a newer style key/fob and they said I was looking at about 175 bux to buy the key and get the key cut/programmed and the fob programmed. then I asked how much for just another key like I have and it was 95.
I might be able to save a few bux by buying the key/fob off ebay and just have them cut and program the key part and ill program the fob portion.
Brett
post #9 of 105 Old 10-28-2013, 05:26 PM Thread Starter
Quoted: 278 Post(s)
I will add the only bad thing that I have noticed so far is the ebay key does not have a ford logo on the back of it.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #10 of 105 Old 10-28-2013, 05:47 PM
Good to know. Thanks.
2008 F450 Lariat, Job 2, 4.88.
2007 Weekend Warrior CR3905
Dave I. is offline
