ESOF - Ford Powerstroke Diesel Forum
post #1 of 12 Old 10-23-2013, 11:59 PM Thread Starter
ESOF
2008 f450 hubs not locking in auto. Light comes on. Transfer case engages. I do not have an issue with the defrost coming on. Vacuum pump comes on as soon as I switch to 4 wheel and does not shut off. Brand new selinoid installed by the battery. Where do I look now?? What could be the issue?
Zacfrd is offline
post #2 of 12 Old 10-24-2013, 12:13 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
It's a vacuum leak... Here is a link to help diagnose the ESOF
http://www.powerstroke.org/forum/att...-work-esof.pdf
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 12 Old 10-24-2013, 08:54 AM Thread Starter
Even though I am not having issues with my defrost?
Zacfrd is offline
post #4 of 12 Old 10-24-2013, 09:10 AM
The leak is probably after the solenoid. Even with the leak, there might still be enough vacuum at the top of the system to run your defrost. It's not an extensive vacuum system, so hopefully it's not too tough to track down.
I was having issue with my ESOF a while back too. Turns out one of the vacuum lines came unplugged at the back of the hub. Easy fix.
B. Adams is offline
post #5 of 12 Old 10-24-2013, 09:33 AM
TD-5's Avatar
Quoted: 3 Post(s)
I believe all the climate controls use electronic blend dampers now, & no vacuum. If your Vacuum pump only runs continuously after you switch to fwd, then it must be as the OP says in the previous post. Check the plastic vacuum lines that run to each hub.
Here is a link to another thread with a write up on the whole system, Post#2, good info
4x4 engagement question - PowerStrokeNation : Ford Powerstroke Diesel Forum
2010 F350 KR CCLB, mini max, H&S pyro kit, ARP studs, II 71/59 billet turbos, RCD ported intake, ceramic BD 6.0 exh manifolds, stainless uppipes, SDP 4" ceramic downpipe, 5" MBRP stainless, sinister egr delete with intake elbow, 3" CAC cold side pipe, BD boots, AFE custom air intake, AirdogII, Mann&Hummel CCV filter, 4.10 Yukon locker rear, Eaton TrueTrac front, Coolant filter
TD-5 is offline
post #6 of 12 Old 10-24-2013, 07:10 PM
Clayton1985's Avatar
Like others said...vacuum leak.
Ive got my pump unplugged as Im too lazy to find and fix my leak. Has no effect on HVAC.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #7 of 12 Old 10-24-2013, 08:22 PM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
Hey guys. Mine does the same thing but I think my hvac is different then you lariat and king ranch guys. I got manual hvac not electronic. My defrost works fine, think it's still a leak somewhere? It's for sure been like this since 20k miles and has 37k now.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #8 of 12 Old 10-24-2013, 08:59 PM
Quoted: 8 Post(s)
The hubs can be taking apart and the O-rings replaced. If it's not the vacuum lines then 9 times out of 10 it's just a O-ring or seal.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 12 Old 10-25-2013, 07:56 PM
Quoted: 45 Post(s)
When it happened to me the dealer replaced the solenoid then the hubs...
2015 F350 DRW Platinum, SCT X4, EDGE CTS2, aFe PDS, AirLift 5000 Ultimate & Wireless Air, Lund LED Bull Bar, RC Grille bar, B&W 5th Wheel, Stark LED Lighting
2010 F250, H&S Mini Maxx, aFe PDS, Diamond Eye 4", Pro Comp Nitro 2.5", Bilstein 5100, SmittyBilt Bull Bar, Bushwacker Pocket Style, B&W Slider, Firestone Ride-Rite, Fuel Hostage 20x10, Pioneer/Kicker/JL Audio
RUFFSTUFF is offline
post #10 of 12 Old 10-27-2013, 10:30 AM Thread Starter
ok so i traced my leak to the hub itself. Where should I start. What inside there can go bad causing the leak and how do you fix it?
Zacfrd is offline
