Winter time - do you run a less hot tune? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 10-23-2013, 06:10 AM Thread Starter
Question Winter time - do you run a less hot tune?
So, on my 6.0 I would just return to stock for winters after some people locally told me they never ran a tune during the colder months around Ohio. With the 6.4 that would mean putting the old exhaust back on, etc. and that isn't happening.
My questions is, what are people with cooler temps doing for winter? Not talking like 40s, I am talking like 20's for days straight, or colder. I am in OH, just south of the lake effect snow, and do use a block heater for 3 hours+ daily before I start her up. Then let her run a bit before dropping the kid off at daycare and starting my 40 min commute.
I have an SCT Livewire, canned tune, then 3 Gearhead tunes, tow, street, hot street. Right now I am running the tow tune to see what the MPG is, and was hoping to run the street again next week to do the same. It's my first full week driving the truck daily as I sold my commuter that was costing too much money in the long route.
So thoughts are I may just run the canned tune or tow tune as I am sure they are not as hard on the motor as the street or hot street. Or am I being overly cautious? My friend with a Dirty that plows(2010), runs his on full tune all year long, and he is in the snow belt and about 10 degrees colder on average.
Thanks!
2010 Ford F250 XLT ; 5" Diamond Eye DP Back ; 2" Rough Country Leveling Kit ; 18x9 XD Hoss's wrapped in 33 Mastercraft AXT's ; 4" Top Gun Customz Blocks ; SCT Livewire w/ Gearhead Custom Tunes : AFE Stage 2 CAI
madcat6183 is offline
post #2 of 15 Old 10-23-2013, 01:09 PM
srjd's Avatar
Quoted: 2 Post(s)
I run the lowest tune I have so on my h&s running hd300 the lowest tune is 40hp. A couple buddies out here I know run spartan and he leaves his on the 275 even when it gets down to -30 -40.
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 15 Old 10-23-2013, 03:02 PM
montana6.0's Avatar
Yeah I just run mine on stock setting on my mini maxx. And have the defuels set for coolant and oil for the colder weather.
2010 F350 auto
2inch leveling kit
35'' toyo m/ts
20'' montsers
dpf cat delete
h&s mini Max
s&b cai
montana6.0 is offline
post #4 of 15 Old 10-23-2013, 03:27 PM
JER-1's Avatar
Quoted: 17 Post(s)
I run tow tune 60 hp in summer pulling boat ect. it keeps the oil and coolant temps down ,in winter I hop it up to extreme 100 hp. it's cold enough to keep temps down plus don't tow much in winter.
JER-1
FOR SALE $19,000
2005 F-350 DUALLY
SUPER DUTY XLT
4X4,CREW CAB 8' BED
FACTORY TOW COMAND BRAKE SYSTEM
FACTORY UPFITTER SWITCHES
EDGE EVOLOUTION 11 GAUGES BUILT IN ONE
ACCUFAB INTAKE MANIFOLD
ZOODA MOD
KITTY RAN OFF
85,600 MILES, 4.10 REAR
PREVENTIVE MAINTENENCE BELOW
SINISTER EGR DELETE
OIL COOLER REBUILD
STC FITING IN HPOP REPACED NEW UPDATED ONE
COOLANT SYSTEM FLUSH 2015
NEW CAT COOLANT 11/2015
DIESELSITES COOLANT FILTER SYSTEM
7 NEW NITTO TERRA GRAPPERS
BLUE SPRING UPGRADE
JER-1 is offline
post #5 of 15 Old 10-23-2013, 03:34 PM
Clayton1985's Avatar
I use spartan 210 during winter months.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #6 of 15 Old 10-23-2013, 07:37 PM
srjd's Avatar
Quoted: 2 Post(s)
Jer your truck shouldn't run that much hotter with a higher tune. Especially only 100hp tune. I can run 300hp tune and all temps stay the same
srjd is offline
post #7 of 15 Old 10-24-2013, 08:51 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
You don't have to turn the power down. It's just crucial to let it get up to temperature before beating on it. I would run it on your tow or street tune and you will be fine. I run my mini max on tow and when plowing I usually turn it down to "stock" which is the lowest hp setting on the switch on the fly because it can get kinda crazy plowing with the tune turned up hahahaha
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #8 of 15 Old 10-24-2013, 12:18 PM
Powerstroke Happy's Avatar
I just let'er warm to operating temp and off I go. All that matters is how you use the skinny pedal. Once engine, trans and differentials are warmed up, the rest is all you. I set mine on my H&S to the HD300 and never looked back. You can blow it up in the cold just as easy as you can in the heat.
09 F-250 Lariat 6.4 Deeehezl
Crew Cab - 4x4 - Short Bed
Fully Loaded
Mods:
Dieselsite Coolant Filter
AFe Drop-in Replacement CAI Filter
H&S Mini MaxTuner HD300
Hollowed out DPF and CAT
4" Superlift (Front)
6" Icon 1pc Blocks (Rear)
Nitto Trail Grapplers:
LT325/60R20 (35.12 H x 12.91 W)
oh yeah, almost forgot...530 RWHP and 1050 TQ
Powerstroke Happy is offline
post #9 of 15 Old 10-24-2013, 12:47 PM Thread Starter
Thanks all, so far the tow tune is holding fine in the fall temps, may try to street tune then just to bump it up a tad and hopefully improve the MPG a little too. Then again, swapping to winter wheels/tires next weekend and taking a lot of weight off the axles with the stockers.
post #10 of 15 Old 10-24-2013, 03:37 PM
bentstroke_02's Avatar
I have Spartan and I run the 275 tune damn near year round until the snow hits the ground then I will turn it down a lot. The higher tunes just lets the tires spin to easy
Jeremiah
Horsepower is like sex, once you get it you can't get enough of it
2008 6.4 with 200k and counting
5" FLO-PRO exhaust W/6" tip
AFE stage 2 CAI
Spartan tuner
PTP EGR Delete
coolant filter
CCV Mod
leveling kit
4in rear Blocks
20's W/35's
bentstroke_02 is offline
