Help! new truck dpf deleted no tuner! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-22-2013, 05:24 PM Thread Starter
I just got me a new truck. 2008 f350 king ranch with a 6.4. The truck does not have a dpf filter or a cat and the sensors on each end of the dpf are gone so the plugs are just tied up. the truck does not have any issues, no check engine lights, and will puff a little bit of black smoke if I get on it. so I assume it has a tune in it to turn off the check engine light and avoid a regen. is there anyway to see the manufacturer of the tune? should I worry about not having a programer? should I worry about not having any of the old dpf parts? is there any way to backup the tune that is in it just in case?
Georgehine is offline
post #2 of 8 Old 10-22-2013, 05:53 PM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
Of its tuned, you should be OK, but you need to make sure ASAP. Does it say it's in regeneration all the time? They regeneration process dumps fuel into the cylinders on exhaust stroke to light off the dpf. It can cause some serious problems if not addressed
Sent from a phone that makes calls too!
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #3 of 8 Old 10-22-2013, 06:03 PM
BlackSheep5's Avatar
The truck will not start after being started once with all of the sensors in the exhaust being unhooked.
If it runs and drives fine then it IS tuned. There is no way to tell by what tuner.
You never got a hand held programmer with the truck?
Sent from AutoGuide.com App
08 F250 6.4L FX4
BlackSheep5 is offline
post #4 of 8 Old 10-22-2013, 06:13 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 270 Post(s)
What I would do if I were you would be buy a new tuner and then take the truck (once you get the new tuner) to the dealership and have it reflashed back to stock. Then you can load your new tunes and live happily ever after.... hopefully
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #5 of 8 Old 10-22-2013, 06:14 PM
Quoted: 398 Post(s)
Garage
X2
post #6 of 8 Old 10-24-2013, 10:01 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
If you buy an h&s with dpf delete tunes, there is no need to go to the dealer and get it reflashed. H&s stores the stock tunes on their system so it doesn't save your stock tune so you can just buy an h&s and press down load tune and tune the truck with h&s tunes. It will throw the tune away that's on the truck and this way you will be able to return to stock if needed. You really need a tuner and some gauges. It will also allow you to check codes and etc.
It can be a bad thing not having the dpf and stuff when you bought the truck. If they bring e check to where you live your gonna have to buy or borrow someone's stock exhaust to get it passed. So it just depends what goes on with our government and your state. But I definitely suggest to buy a tuner and keep and eye out for someone selling stock exhaust for cheap. But try to find who ya bought the truck from. He may have it and may have kept the tuner thinking it's worth something not realizing it's locked to the truck he sold.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #7 of 8 Old 10-24-2013, 10:41 AM
Quoted: 270 Post(s)
Are you sure about that? This very thing happened to a friend of mine that owns a car dealership and he had to take the truck and get it reflashed before he could install the new H&S.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #8 of 8 Old 10-24-2013, 11:41 AM
I'm in the same boat with the dpf being deleted with no tuner. Im on my way to finalize everything today I had them check the coolant for exhaust gases and it came back good the coolant looks brand new and no obvious leaks what do you guys think?
Dieseloutlaw270 is offline
