6.4 cold weather - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-22-2013, 04:09 PM Thread Starter
6.4 cold weather
Hi Everyone,
I have a few questions I need some help with. I have an 08 f450 with emissions removed. When it is cold out it seems to run different. It is in the 30's here now and it seems sluggish and you can hear a pitch change in the motor around 1800 rpm. It almost sounds like a rattle. Not sure where it is coming from? Also what oil should I use in cold weateher?
Zacfrd is offline
post #2 of 9 Old 10-22-2013, 07:19 PM
Clayton1985's Avatar
Where is "here"? How cold does it get? 30s isnt cold so if its sluggish now it might get worse?
I live in a pretty cold place myself, I run 5w40 (shell t6) year round. Is it warmed up at least a bit when you notice it runs different?
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #3 of 9 Old 10-22-2013, 11:47 PM
srjd's Avatar
Quoted: 2 Post(s)
What he said. 30f where Clayton is from people are still in shorts and t-shirts
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 9 Old 10-23-2013, 06:15 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Haha that's crazy. If it gets below zero here its really cold. What kind of temps do you guys see?
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #5 of 9 Old 10-23-2013, 07:48 AM Thread Starter
Im in wisconsin. Even when the truck warms up it is doing this. at 1500-1800 rpm i heaar this rattle almost like a gasser lifter noise. it goes away at low or high rpm. when it is making this noise it seems like I loose some power. when warm out side i do not hear it as much and is seems like there is more power. I dont know if it is injectors, turbo, fuel, or what. no codes
Zacfrd is offline
post #6 of 9 Old 10-23-2013, 01:06 PM
srjd's Avatar
Quoted: 2 Post(s)
No clue what your issue is sorry man. Its not uncommon to see -40 in Alberta. At the temp F and C are the same
srjd is offline
post #7 of 9 Old 10-23-2013, 02:24 PM
mine does it to someone said its injector raddle but mine runs fine when doing it
seeder is offline
post #8 of 9 Old 10-23-2013, 02:28 PM
bmxrules798's Avatar
Send a message via AIM to bmxrules798 Send a message via Skype™ to bmxrules798
I haven't seen any issues up here in North Dakota where is can get to -75 out and the only thing that's happened to me was it gelled up on me when I for got to put my additives in when it was -56 out but that was fixed with a little heat.
2008 F-350 XLT 6.4l and loving it
Mods:
S&B Intake, H&S Mini Maxx Tuner, MBRP 4in Downpipe Back Exhaust, High Idle Mod, 5% Tint all around, Sinister Coolant Filter, Sinister Full EGR Delete, Mishimoto Intercooler with 3in cold side pipe, 55w 5k HID Headlights and Fogs, Recon LED taillights, 3rd break light, and mirror lights.
bmxrules798 is offline
post #9 of 9 Old 10-23-2013, 03:32 PM
If I now know of what you speak, which I think I do, I have noticed it in every powerstroke I have driven including my personal truck. No idea why or what it is, but one of those things I just associated with cold weather/cold soaked engine..
1999 Corvette Cpe
