Is it OK to tow a 5000lb trailer with Hot Tunes ? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-21-2013, 02:39 PM Thread Starter
I've read about guys towing light trailers on the hot tunes, and monitoring EGT's. I haven't tried the IDP tow tune just driving around, but every tune other than "Xtreme X" is downright anemic.
Anyone tow a 5000lb trailer (car trailer + 3000lb car) on the hot tunes?
'08 F250 Regular Cab 4x4 (sold)
MBRP dpf delete
MBRP intercooler pipe
S&B intake
IDP/ SCT tuned
Suncoast Trans (built by Quin Trans in Lompoc, CA)
Cal-Tracs
Eaton Tru-Trac
12.76 @ 105.50, 1.80 60ft (before trans or intercooler pipe)
lxcoupe is offline
post #2 of 7 Old 10-21-2013, 04:08 PM
08forddr's Avatar
I towed my 11, 000lb 5th wheel on th x street tune. Did have a problem till I started going through the mountains. Then I had the wrench light and loss power and threw a overboost code. I think you woukd be fine on the street tune towing on the highway.
2008 CC Lariat short bed
35x12.5x20 XD Hoss , Leveled
Sct tuned by IDP , Air bags
08forddr is offline
post #3 of 7 Old 10-21-2013, 07:45 PM
Clayton1985's Avatar
Ive towed the same weight setup (~6000lb) while running spartan 275. No problems.
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #4 of 7 Old 10-22-2013, 05:03 PM
I tow everything on the 275 spartan. Drive with you brain not your foot and you will be fine. I've done 12000 pounds on the 275. Take it easy and dont rush
Trouble maker is offline
post #5 of 7 Old 10-22-2013, 07:39 PM
WoodBoy's Avatar
Ive used a tow tune once towing and it sucks. I tow on whatever tune I have loaded now which is usually a275 to 330 tune and no problems but I do run my monitor when towing
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #6 of 7 Old 10-24-2013, 07:19 PM
I tow more than that all the time running my HD300 tune. Just watch your EGT's and boost.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #7 of 7 Old 10-25-2013, 07:49 AM
10k lbs here on the hot tune, my defuel settings are fairly low and climbing through mountains the coolant temp defuel kicks in a few times and it just turns the tuner to stock.
rdwngs444 is offline
