some questions on my 6.4 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-17-2013, 10:40 PM Thread Starter
Hey guys just had a few questions about my 08 F250 King Ranch Lariat.
Im running h&s mini maxx on hd300 (stock tranny), s&b intake, 5in downpipe back diamond eye exhaust, and sinister egr delete.
Around about what numbers should I see to the ground?
How much boost will turbos hold?
Im defueling at 42psi what is a safe psi without studs?
What are some other defueling parameters to set?
What temp does egts start to get to hot?
How well does stock tranny hold up?
Should I look into trac bars?
What should ve my next few upgrades?
Should I look into custom tunes? If so which ones?
Thanks for any help im kinda new to diesels so I could use a lil help on a few things.
08powerstrokef250 is offline
post #2 of 7 Old 10-17-2013, 11:20 PM
srjd's Avatar
Quoted: 2 Post(s)
Stock turbos can see up to 55psi with some tunes. Defile at 42 is safe, I have mine set for 40 and I have studs but I drive like a gramps. Your stock studs honestly are luck of the draw. As far as traction bars if you have the money put them on if not and you don't have a lift its fine but never hurts. Egts I can't tell you the last time I seen over 1000 so sino e else can chime in on that one. Hope I answered some of your questions
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 7 Old 10-18-2013, 12:54 AM
BIG Laing's Avatar
Keep egt's below 1000 K
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #4 of 7 Old 10-18-2013, 08:32 AM Thread Starter
Well I know keep you egts under or around 1000 but at what point do you want to let out when your at WoT?
post #5 of 7 Old 10-18-2013, 11:45 AM
srjd's Avatar
Quoted: 2 Post(s)
These 6.4 can take a lot of heat I heard stories on here of 1600 to even 1700 one time. At a wot run you should see around 1300-1500 depending on exhaust and intake/ other mods. As long as you are only holding it at those temps for a second or two it should be fine. This is just going g off things I see and hear around here. I didn't realize how much I baby my truck till yesterday had throttle % on mini maxx display and thought I was being a bit hard on my truck yet it didn't go over 50% Haha. I had a bad summer last year getting head gaskets done twice and turbos once. 13g later I'm clearly a bit paranoid
srjd is offline
post #6 of 7 Old 10-18-2013, 12:32 PM
BIG Laing's Avatar
1000 K or 1340 F or 727 C is the critical temperature of mild steel....
post #7 of 7 Old 10-18-2013, 02:06 PM Thread Starter
Can anyone tell me about the stock tranny? And custom tunes?
