DPF-R+4.0 - Ford Powerstroke Diesel Forum
post #1 of 13 Old 10-16-2013, 07:22 PM Thread Starter
DPF-R+4.0
I have had the DPF-R+4.0 installed for about 2000 miles. First I installed it without the economy tune. My mileage was about 15 combined and she ran good. After a while I installed the economy tune and my mileage went to 19, great. But along with the economy tune I got a random miss at idle. Truck runs great. My Scan Gauge II shows no codes. I put it back to stock and reloaded just the DPF- tune, no miss. Put the economy tune back, got the miss. I called Sam at GearboxZ and explained the problem. He had no answer except that I might have a weak injector that was showing up with the econ tune. He did suggest I disconnect both batteries, ground one + lead to erase the PCM memory and let the truck relearn. Any of you guys have an opinion?
2010, Lariat Stroke, Sterling Gray Metallic, CC, FX4, SB, 20" factory rims, Wrangler ATS, XDP coolant filter, Truxedo LO-Pro QT tonneau cover, ScanGauge II, DPF-R+4.0, CAT/DPF delete, Flo-Pro delete pipes, stock tips. Stromberg-Carlson power step for the wife.
wargle is offline
post #2 of 13 Old 10-17-2013, 06:16 AM
Does the miss happens every time that the A/C compressor engages? At idle, my truck did do something as a hiccup with the DPF-R+. Used it for around two years without any problems. But I am not sure if you are talking about the same.
2008 F250 FX4, CC, SRW, SWB, 6.4L PSD, Oxford White w/Dark Shadow Grey lower accent,
20 x 9 Black XD Revolver w/Nitto Terra Grapplers 295/60/20,
H&S Mini Maxx, SDP Downpipe/CAT/DPF Delete, Banks Monster Exhaust Dual-Tip, Turbo Socks, DEI Exhaust Wrap (half downpipe),
Banks RamAir Intake, Dieselsite Boots Kit, MBRP Intercooler Tube, Flo-Pro EGR Delete Kit,
Power-Stroke Connection CCV System, Dieselsite Coolant and Transmission Oil Filtration Systems
CaribePickup is offline
post #3 of 13 Old 10-17-2013, 08:11 AM Thread Starter
Not sure about the AC. The miss might happen several times of times within a minute and then again if might happen once in a minute. I'll check to see if there is a corelation.
wargle is offline
post #4 of 13 Old 10-17-2013, 10:36 AM
Forgot to tell that I sold the DPF-R+ to a friend and his truck does the same as the mine did. At idle has a hiccup every time that the A/C engages and does it only with the DPF-R+ program but not with the DPF-R. He is already used to the hiccup, as I was, and is very pleased with the program. Both trucks are 2008 models.
post #5 of 13 Old 10-23-2013, 01:14 PM
imk0001's Avatar
Subscribed. I am interested in this very programmer so I'm curious as to what the issue was. What kind of power gains did you experience?
imk0001 is offline
post #6 of 13 Old 10-24-2013, 10:29 AM Thread Starter
I really wasn't looking for power adder, just DPF delete. The DPF-R 4.0 has a 40hp adder in the economy mode. Didn't see much difference in power, but the added fuel mileage was 4mpg, by hand. I very satisfied with the mileage. I tow a 28 foot 5th wheel camper and the truck does great at 12 mpg and I'm not killing the motor with the stupid DPF and regens.
wargle is offline
post #7 of 13 Old 10-24-2013, 10:37 AM
08PowerstrokeFX4's Avatar
I currently am running the DPF-R 4.0 with the 70HP Econonmy Tune. My truck does the same thing, has a hiccup when the truck has the A/C running or defrost on. No other problems at all. Talked to a few other friends and they also have the same problem.
On a side note...I do have a DPF-R 4.0 for sale. Installed in March. Switching over to Spartan.
F250 CCSB 6.4L Powerstroke
Spartan Tuned, ATS Trans, Sinister Diesel Goodies, Elite Diesel Goodies, and a bunch under the hood.
We miss you Ron. Thanks for everything you did for us and sharing your knowledge!
08PowerstrokeFX4 is offline
post #8 of 13 Old 10-24-2013, 12:12 PM
imk0001's Avatar
How much are you looking to get for it?
imk0001 is offline
post #9 of 13 Old 10-24-2013, 03:34 PM
$300. I still have the original invoice from Xtreme Diesel Performance when I bought it.
post #10 of 13 Old 10-25-2013, 04:59 PM
imk0001's Avatar
Can you stack this with another programmer? I just picked up an SCT that I want to use as a gauge.
imk0001 is offline
