Additives - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-16-2013, 02:15 PM Thread Starter
Additives
Do any of you guys use any additives on the daily, I live in cleveland ohio so it gets a little chilly up here in the winter i heard the diesel fuel can almost gel up in cold temperatures any truth to that? Ive heard of rev x, and another product called diesel kleen? Any comments or help pros or cons are greatly appreciated thanks guys!
Mmace111 is offline
post #2 of 6 Old 10-16-2013, 04:08 PM
srjd's Avatar
Quoted: 2 Post(s)
Rev x is more so for the 6L it dies wonders in those engines. Chances are in Cleveland area you won't have gelling issues. Where I live it dips down to -40f and I've never had issues. I can't remember the last time I filled up without additives. I use to use diesel Kleen but this summer switched to the ford stuff which is stanadyne in a ford bottle. It will be full blown winter here real soon and I'll switch back to diesel kleen white bottle
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #3 of 6 Old 10-16-2013, 05:14 PM
WoodBoy's Avatar
I run the diesel kleen (grey bottle). But a lot of guys up north I see run the diesel kleen white bottle. I do believe I get better fuel mileage with the ford additives but I haven't bought any in a while.
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #4 of 6 Old 10-16-2013, 05:33 PM
I used ford cetane for three years or since I bought my 2010 f350 but just switched to opti-lude.
Main reason I switched is I can buy it in 5 gallon buckets instead of having all these little bottles every where and plus the buckets come with a pump so I can fill up little 24oz bottles for trips.
Also I think the opti-lude is better and cheaper with volume purchasing.
There's some research that was done about different additive and you will be surprised how some work well and some work bad...
GSchretter is offline
post #5 of 6 Old 10-16-2013, 05:37 PM
SyN
Lubrication Addict
SyN's Avatar
Power Service {White Bottle} when the temp falls below 20F. Have used Howes as well.
Howes Lubricator
It never has dropped in the negatives here but in the teens and 0F many times last winter. I am not taking any chance. I fill up at Loves 1 block away with B19.
01F250-4WD-XLT-AUTO-CC-7.3L-{295K} Miles
Donaldson AIS Intake System w/Zoodad
4''Turbo Back MBRP Exhaust
Remote Spin-on Coolant Filter/Red {ELC}&RMI-25
Remote Spin-on Transmission Filter/Lg Magnet
203*F T-Stat w/Billet Housing
CCV Re-route
SS HPX Line
Many Other Small Mods
Oil-------->T6 w/Amsoil Filter & Lg Magnet
AMSOIL-------->Every where else
SyN is offline
post #6 of 6 Old 10-18-2013, 03:25 PM Thread Starter
Thanks alot guys i really appreciate it!
Mmace111 is offline
