coolant filter questions - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-15-2013, 05:22 AM Thread Starter
CNYWhiteDually's Avatar
Where did everyone tap their lines into for their coolant filters..??
i want it to take the biggest sample it can while not having alot bypassing it.
anyone have some pictures of where theirs are installed?
CNYWhiteDually is offline
post #2 of 4 Old 10-15-2013, 01:25 PM
StrokiNDieseL's Avatar
I don't remember the members name but there is a good thread on how to do coolant filter addition w/o draining coolant & utilizing clamps to prevent leaking as you install fittings. I'll see if I can find something, but you tie into smaller hose leading into degas bottle that runs on top of radiator & I believe it's the heater core hose on fire wall once air box is removed. Maybe someone can provide the link.
08 F250 6.4L
CcSb Lariat 3.73
5200lbs springs, rear blocks removed, Nitto Grapplers
aFe Mag Force II Si pro 5R w/modded box
H&S MiniMax/Mcc & Gearhead tunes w/Blendmount
aFe Mach Force XP 4" Exhaust w/downpipe
Custom-Diesel Deleted, H&s wastegate w/Intake Elbow & CAC pipe, MPD Ccv/Oil fill mod, Alradco intercooler,
SD Coolant filtration/ CAT ELC...
StrokiNDieseL is offline
post #3 of 4 Old 10-15-2013, 05:11 PM
Buy a kit and use vise grips on each side of the bottom heater hose so when you cut it coolant doesn't leak out.
I
GSchretter is offline
post #4 of 4 Old 10-15-2013, 05:20 PM
Link: http://www.google.com/url?sa=t&rct=j...372,bs.1,d.eWU
Or google coolant filter installation for a 6.4L & it comes up right away.
08 F250 6.4L
CcSb Lariat 3.73
