What do you think? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-13-2013, 08:36 PM Thread Starter
Rocweiller's Avatar
Quoted: 2 Post(s)
What do you think?
Well last week I traded my 03 6.0 in one a 08 6.4. Gonna get tuned when I have the spare cash. Well well the ac or heater.(does with both on) it makes a thumping or popping noise from right side in the front. Thought maybe vacuum pump but that is on the other side. No noise when heat or cool is off. What is going on? Compressor cycling? And if so is that Normal? Also when I was on a steep grade and disengaging 4 low in made a terrible sound from under truck twice and would stop once I put in park. Flat ground and slight grade no noise . Any ideas on these noises? Thanks
2008 F250 XLT SBCC grey flake, 33x12.50 Toyo m/t's on 18 inch mammoth wheels. Rhino lined go rhino nerf bars. S&B cai,Spartan tuned and straight piped. Fake *** chrome grille removed and a matching colored grille put in place.
Rocweiller is offline
post #2 of 5 Old 10-13-2013, 08:49 PM
me personally only engage 4x4 / disengage if I'm not moving or if costing on flat surface i would never try to disengage 4x4 on any type of steep grade. id keep it in 4x4 and not switch till your on a nicer surface..
my truck also makes the dash sound.. my guess is the blendoor acting up
08 F350 Green/tan
ThcGunSmoke is offline
post #3 of 5 Old 10-13-2013, 09:23 PM Thread Starter
Rocweiller's Avatar
Quoted: 2 Post(s)
That's weird about the noise, my buddies dads 08 doesn't make any noise.
post #4 of 5 Old 10-14-2013, 09:46 AM
illadvised's Avatar
I get a similar noise... it comes and goes quickly about 2K RPM.
I have not yet replaced this hose to see if this is the issue or not. I will copy and paste the TSB below. This was pulled from a another site.
TSB
07-24-2 6.4L ENGINE BUILT BEFORE 06/18/2007 - HEATER CORE NOISE - ALSO DESCRIBED AS GURGLING, RATTLE, OR SCRAPING NOISE
Publication Date: November 21, 2007
FORD: 2008 F-Super Duty
This article supersedes TSB 07-22-2 to update the description in the Issue statement.
ISSUE:
Some 2008 F-Super Duty vehicles equipped with a 6.4L engine and built before 6/18/2007 may exhibit a gurgling type noise coming from the heater core. It has also been described as a rattle or scraping noise. It has also been incorrectly identified as a torque converter concern.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Bring engine to normal operating temperatures.
Raise engine RPM to 2500-2900 range.
Using a hose clamp tool, crimp the heater inlet hose. If the noise goes away, replace the inlet heater hose.
If the noise does not go away, proceed with normal diagnostics.
NOTE: DO NOT ADD AN ADDITIONAL RESTRICTOR TO THE LINE OR MANUALLY MOVE THE EXISTING RESTRICTOR.
NOTE: DO NOT REPLACE THE HEATER CORE.
PART NUMBER PART NAME
7C3Z-18472-K Heater Hose (With Auxiliary Heat Controls)
7C3Z-18472-L Heater Hose (Without Auxiliary Heat Controls)
08 F250 KR CC | Mini Maxx | Studded | 4" Turbo back | Full Delete W/Elbow | AFE Drop in | 35" BFG AT
E99 | Stage 2 ind inj | Van Turbo | 17*HPOP | DP Tuner | 4" Turbo Back |13" Lift | 40x15.5R22 Mud Grapplers | 08 tails-SOLD
illadvised is offline
post #5 of 5 Old 10-14-2013, 08:45 PM Thread Starter
Rocweiller's Avatar
Quoted: 2 Post(s)
Keep me posted on this. Thanks
