Alignment after steering gear replacement? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-13-2013, 08:57 AM Thread Starter
rt_hawk's Avatar
Should I get my truck aligned after I replace the steering gear? I just got it aligned 4 days ago when I was trouble shooting my steering issue, it did need an alignment pretty bad and now it tracks great...but the steering gear is the main problem...so is an alignment really needed after a steering gear change out? Both connections on the gear are keyed...so you can't mess it up...I just can't see much getting out of adjustment by taking off the parts and bolting them back together...also the workshop manual says you can't reuse the bolts that mount the steering gear to the frame...Can't I just locktite them if I reuse them? Or should I get new bolts from a hardware store and use locktite?
Thanks in advance everyone!!
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
post #2 of 6 Old 10-17-2013, 10:27 AM Thread Starter
rt_hawk's Avatar
Anyone?? Swapped out my steering gear with a napa reman...holy crap! I have a new truck again! Smoothest steering ever ! On the old box I couldn't even turn the pitman arm with a 6 foot breaker bar when removing the large nut that holds it on ...the shaft on the pitman appears to be almost an inch lower than on the new one...and the input side of things was extremely hard to move as well...I am guessing I was close to completely losing all steering...
rt_hawk is offline
post #3 of 6 Old 10-17-2013, 11:20 AM
Tag for update. Mine's getting replaced under my ESP right now. Only 40k on it and needs new steering box and tie rod ends.
jerrmy is offline
post #4 of 6 Old 10-18-2013, 11:20 PM
Picked my truck up today. They did the alignment after replacing the steering shock and track bar bushing and ends. Steering gear won't be in until late next week. They said there is no need to do the alignment again after replacing the steering gear.
Hope this helps.
BTW so glad I got the ESP on my truck!! Paid for itself twice already!
jerrmy is offline
post #5 of 6 Old 10-19-2013, 03:44 AM Thread Starter
rt_hawk's Avatar
Thanks a lot Jeremy, I appreciate you letting me know!
rt_hawk is offline
post #6 of 6 Old 10-19-2013, 08:40 AM Thread Starter
rt_hawk's Avatar
I also replaced my drag link (inner)...I messed up the threads with the gear puller and it was shot anyway...but I counted the number of turns it took to come off and then I replaced the adjustment sleeve and made sure it all measure the same length as the previous one... So far my wheel is still centered and steering is spot on...just FYI...and if anyone needs a easy way to bleed a PS system I used my mighty vac and a 3 dollar rubber stopper with a hole in it and applied vacuum through the PS resevoir...you apply vacuum till it gets tight, slowly release it, and repeat until the fluid level stops dropping/bubbles stop coming up...
rt_hawk is offline
