Changing ATF in 2010 SD - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-12-2013, 05:29 PM Thread Starter
Vet4jdc's Avatar
anyone able to give me some simple step by step instructions for changing automatic transmission fluid. I don't want to flush it....just drain and refill with Mercon LV.
Thanks!
2010 F250 SD 4x4 / DPF Deleted / 4" AFE Straight Pipe / Spartan Tuned / S&B CAI
Vet4jdc is offline
post #2 of 6 Old 10-12-2013, 08:19 PM
Clayton1985's Avatar
1. Pull plug and drain
2. Put plug back in
3. Fill
2008 Job 3, F350, 6.4/drw/lariat/CC/LB, Spartan, Viper 5902, Line-X, Flo-pro egr delete, aFe stage 2 proguard 7, MBRP Cool Duals/downpipe/CAC, CCV mod, coolant filter PMF 7" 4link, Rigid Dually fogs, Royalty Core 3pc, Crown brake lines, Mishimoto Rad
6.4 Rebuild May/2015, BD manifolds+Uppipes, chromoly rods, rockers,lifters, hd springs
Monstir 20", 37x12.50 ATZ P3
1999 Corvette Cpe
Clayton1985 is offline
post #3 of 6 Old 10-13-2013, 12:49 PM
strokin07's Avatar
It wouldn't hurt to change the filter while you're at it
2008 F-250 KR
7" ICON
7" PMF blocks
Bilstein 5160F/5100R
22x14 Fuel Octane
37" Toyo M/T
H&S Mini Maxx w/ Gearhead tuning!
5" Diamond Eye
4" Diamond Eye DP
ARP head studs
Custom Stock Intake
RCD converter, HD billet input, low/rev hub, suncoast clutches.
160k miles and counting...
strokin07 is offline
post #4 of 6 Old 10-13-2013, 04:30 PM
Oops....
GSchretter is offline
post #5 of 6 Old 10-13-2013, 08:52 PM
Agreed. If you are gonna swap 9/10 qts may as well drop the pan and plunk in a new filter.
1999 Corvette Cpe
post #6 of 6 Old 10-14-2013, 10:25 PM
srjd's Avatar
Quoted: 2 Post(s)
I have a job 1 only ever dropped what's in the pan and changed the external. On the job 1 is it worth cleaning the screen inside. Sorry for the hijack
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
