Transmission - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-10-2013, 04:51 PM Thread Starter
08forddr's Avatar
Transmission
This doesnt happen all the time but my trans slips every now and then. Always when cold and it happens when I go about half throttle, let off and then hit throttle again. Could it be the trans or something with my tuner?
2008 CC Lariat short bed
35x12.5x20 XD Hoss , Leveled
Sct tuned by IDP , Air bags
08forddr is offline
post #2 of 9 Old 10-10-2013, 08:23 PM
WoodBoy's Avatar
Are you sure its not the common rev up and then catch from the 5R110?
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 9 Old 10-10-2013, 09:27 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 17 Post(s)
Transmissions are not efficient when cold but check your fluid level. Is it happening on anything other than level ground (not turning)? My next step would be to lose the SCT and see what happens.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #4 of 9 Old 10-11-2013, 05:15 AM Thread Starter
08forddr's Avatar
I guess it could be because it dont happen all the time.
08forddr is offline
post #5 of 9 Old 10-11-2013, 05:19 AM Thread Starter
08forddr's Avatar
Yes just happens on level ground. Its only now and then. It does seem when the engine rev, s up and I let off the pedal and then get back on the pedal it happens. So maybe the engine didnt get a chance to rev back down before I hit the throttle again?
08forddr is offline
post #6 of 9 Old 10-11-2013, 05:30 AM
Quoted: 17 Post(s)
So when you let off the pedal, the RPMs drop like normal but when you press the pedal, what does it do? Is there a spike in RPMs (like the clutches are slipping) and then it grabs, loading the engine and bringing the RPMs back down?
You might have to replicate it again, taking note of the RPM range when this occurs. Heck, a video would be great. Also, is this every gear or one in particular at a certain speed?
Still check your trans fluid and try taking the SCT off to see what happens.
2001 7.3L
Pro Comp 6.5" Lift
Tru-Cool Max
Centramatics
EBPV Switch
Foil Delete
Zoodad
post #7 of 9 Old 10-11-2013, 06:05 AM
WoodBoy's Avatar
Im pretty sure he is just experiencing the common rev and slam that everyone talks about. Even if it isn't slamming it is still catching after reving. All 5r110s are known for this.
WoodBoy is offline
post #8 of 9 Old 10-11-2013, 06:18 AM Thread Starter
08forddr's Avatar
I am think you maybe right. So I shouldnt worry?
08forddr is offline
post #9 of 9 Old 10-11-2013, 07:33 AM
Combs19's Avatar
If yours is happening in the 3 to 5 gear range it maybe a shift flare. My truck would rev up every so often when it was shifting between 3 and 4th gear and it woud feel soft and mushy when it did it. For me it would only happen or I would only notice it when I was at half throttle or less and once again this would only happen every so often. It would also feel like it would get stuck inbetween gears or couldn't find the right gear sometime if I was braking hard for a stop light and then get back into the throttle before coming to a complete stop. To fix it for me I first tried traction bars thinking that woud fix everything but it didn't. Traction bars are great for everything expected fixing the shift flare. The thing that fixed it for me was a modified DD shift solenoid from PTP for $150. It makes the 3 to 5 gear shifts faster and more solid feeling. I've had mine installed for maybe 500 miles or so and not one shift problem yet. I hope that helps. If you do it I would recommend doing a transmission relearn on it after install. My shifts were a little to firm at first until the relearn was done.
2008 F350 Crew Cab Harley Davidson
Early 99 (converted to Late 99) Sold!!!
F250 Crew Cab short box
Mods: S&B Intake, H&S Tuner, Delete Pipe, Newton 2 1/2" Leveling Kit with 5.5" traction bar blocks, 305/60R20 Goodyear Silent Armor Tires on Stock Harley Rims.
Combs19 is offline
