upfitter question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-08-2013, 06:28 AM Thread Starter
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
upfitter question
ok so im wanting to wire up a 20" led light bar. says 120watts at 12 volts which if i did my math right it should pull right about 10 amps.
upfitter #1= 25amps (already used for plow lights)
upfitter #2= 25 amps (already used for strobe lights)
upfitter #3= 10 amps
upfitter #4= 15 amps (already used for led back up lights)
is there any way to bump upfitter #3 up to 15amps or will i be okay to run my light the way it is. I was looking through my owners manual and seen the fuses for aux 1 and 2 but didnt show any fuses for aux 3 and 4? if worse comes to worse i could switch my back up lights to 3 and run my light bar off the aux 4 with 15amps. let me know what you guys think. the place i bought the light bar off of said to run a 30 amp fuse for the light bar but that seems too big. I dont know hopefully someone can help me out. thanks
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #2 of 4 Old 10-08-2013, 06:32 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Well if worse comes to worst then you could just use a relay on your upfitter to trigger the light.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 4 Old 10-08-2013, 06:42 AM Thread Starter
travisH3's Avatar
Quoted: 2 Post(s)
there is enough wiring on this truck, i need to keep it as minimal as possible but thats definitely an option. thanks!
T-rav
2010 F350 6.4-
travisH3 is offline
post #4 of 4 Old 10-08-2013, 06:47 AM
Chapter Director
Quoted: 5 Post(s)
Hell i know what you mean, If you look under my truck, engine bay, or under dash it looks like a damn spider web
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
