Need Opinions and Thoughts - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-07-2013, 10:57 AM Thread Starter
Quoted: 35 Post(s)
I'm considering selling my 7.3 and hopping into a 6.4. I found a pretty clean 08 F250. The guy hasnt done anything to it besides a lift and tires. I know I'll need to do the basics, EGR delete, DPF Delete, gonna throw out the CAT as well, get a Tuner and I think thats it, right? Anyways, what are your guys thoughts or concerns or tips about this truck and what I should check out when I go and take a look at it. This is a pretty reasonable price for these trucks in my area (Cali) for the mileage it has. How much do you think I should offer or look out for or check when I go out and look at it. Thanks in advance. Always eager to learn more about these trucks so gimme all the info you got!!
2008 Ford F250
Tony Smith
2006 F250 Fummins with Allison Transmission
Fully loaded with all the goodies
Planning: Carli 4.5" Backcountry with full deaver upgrade
SOLD
New ride: 09 JK Unlimited with Rubicon Drivetrain fully built up
LTSmith is offline
post #2 of 4 Old 10-08-2013, 04:44 PM
Lipka101's Avatar
Quoted: 87 Post(s)
Search the problems with these trucks. Mostly coolant issues I think. Check the build date. I think to avoid leaking radiators you want with late 07 or 08 build dates. So check coolant levels and make sure it has been maintained properly. Fuel filters and such. Looks like a nice truck for a decent price. I just paid 28 for an 08 king ranch with 96k. Also if you tune it get a high flow intake or it will set off the filter minder when you go over half throttle.
2008 f250 ccsb kingranch
Sct Livewire with Gearhead custom tunes. Edge insight cts.
Mbrp dpf/cat delete. PMF stage 2 traction bars.
Drp egr delete w/wastegate. LP batmowheel, 22x9.5 fuel hostage with nitto terra grappler. 12.9 sec. 1/4 mile at 104.5 mph
Lipka101 is online now
post #3 of 4 Old 10-09-2013, 04:23 AM
Say hello to the new 7.3.....I mean the 6.4. The 6.4 is a great motor, you need to delete as you mentioned and maintenance is a must. How many miles are on the truck? I'm only asking, because I'm not sure I would buy a high mileage 6.4 that has not been deleted.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #4 of 4 Old 10-09-2013, 08:37 AM
srjd's Avatar
Quoted: 2 Post(s)
Chances are if you buy a early build date like mine 01/07 the bugs will be worked out but maintenance is key it needs a lot more attention then old faithful
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
