p0263 and occasional p0088 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-06-2013, 03:15 PM Thread Starter
My truck has 130,000 on it and Im getting contribution code on cyl 1 so im replacing the injector. While im in there also doing the egr delete since im slowly loosing coolant. Hoping its a leaky egr cooler. While im in there what else do i need to do.
Also, the p0088 code when cleared doesn't come right back. Do i have a faulty hpfb or can the injector cause this to throw a code sometimes. Truck runs fine with good power. Ive done the dpf delete and running a spartan tune since about 65000 miles.
Also..if i have to do a hpfp would it be a good time to do a down pipe and would it be beneficial. Right now i just have a dpf/cat delete pipe on the truck.
Any advice would be helpful. Thanks
TimH is offline
post #2 of 7 Old 01-26-2014, 07:21 AM
Savagef250's Avatar
My truck threw the p0263 code last night I have a mini maxx and i cleared it. It threw the cold when we had a bad week that went from decently warm to negative temperatures. I cleared the code and haven't noticed the problem again. I'm going to put injector cleaner in it today since it's going to be decently warm and see how it does. Should I go ahead and have it looked at or see how it does and hope the injectors get clean.
Savagef250 is offline
post #3 of 7 Old 01-26-2014, 09:04 PM
srjd's Avatar
Quoted: 2 Post(s)
To the op if your cab hast to come up I'd definitely throw a dp on it wont hurt. I'd also delete the drivers side up pipe if your doing egr delete. Will only take a couple min with cab up and save you future headache.
To savage I'd keep an eye on it cold weather shouldn't throw that code I've started Numerous amounts of times in Alberta winter with no codes
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #4 of 7 Old 01-26-2014, 10:47 PM
B585Ford's Avatar
Have you checked to make sure you aren't getting coolant or fuel in your oil? Have you hooked your truck up to IDS. Do you know how far off this cylinder is? Be careful with this one, a contribution code could always be from a cracked piston (which is fairly common on a tuned 6.4). Have checked for excessive blow-by? A cracked head could cause a contribution code although it is not the most common reason....that could explain your coolant loss too. A cracked block could also do this and cylinder 1 is where most of them crack.
A sticking injector is definitely a big concern because of the potential to melt the piston. I am not trying to scare you...I am just giving you some worst case scenarios.
2008 F350 ZF6 daily driver
No Limits CAI and every air mod, MM w/ GH, DPF/CAT delete 5", Sean's 4" DP, SB DD 3850, Coolant Filter, Bushwacker flares, 2.5" Icon level, SD inserts tailgate/grill, PMF Tbars w/ 5" block, Elite EGR delete, Junior High Power Atmo, ARP studs, A-1000 (Marty's), Fuel Bowl Delete, 15% nozzles, Tial WG
God Bless our military!!!!
Please see this thread:
B585Ford is offline
post #5 of 7 Old 01-27-2014, 06:15 AM
Savagef250's Avatar
To srjd I drove it for about two hours last night and didn't notice anything. Of course today it's back below freezing. I'd of continues to do it what do you think the problem is.
post #6 of 7 Old 01-27-2014, 11:53 PM
srjd's Avatar
Quoted: 2 Post(s)
Could be a number of things like listed above but if you keep getting a contribution code I'd take it in right away to get looked at
srjd is offline
post #7 of 7 Old 01-28-2014, 06:36 AM
Savagef250's Avatar
I haven't gotten any more codes since I cleared that one off. Ive figured out it only sputters after I reslly get on it.
