6.0 vs 6.4 for a drag truck - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-30-2013, 10:19 PM Thread Starter
SPY+'s Avatar
ok so i am really debating a swap into a 1970 ford ranchero gt.
i know it will be a alot of work and what the swap will entail
the truck already has a 460 in it but i want some thing different.
so now comes the debate a 6.0 or a 6.4
i want the most bang for my buck i am shooting for any were between 600 and 800hp.
i am trying to find out witch swap will be the most doable and with the most aftermarket support.
list i need to know before i pull the trigger is
engines wights with trannys
how tall they are
what accessories i dont need to run the engine
do i need the whole wire harness or not
how easy is it to get the hp mark
what engine is more reliable and can take pass after pass at the track
what the end goal here is to have a different kinda cool
and a fast drag car/truck
i am trying to get the most info so i can make the most informed decision
so i can go about this in the right way instead of a hack job
thanks for reading
SOLD:00 F250 CCSB LARIAT 7.3 4'' MBRP TURBO BACK, AIRAID INTAKE, GAUGE POD, INTERNATIONAL UP PIPES,TRANSMISSION COOLER KIT,ADRENALINE HPOP
NEW: 2010 f250 6.4 stock
SPY+ is offline
post #2 of 5 Old 10-01-2013, 02:27 AM
Big_Smokey's Avatar
Quoted: 9 Post(s)
6.4seems to yield a little more HP for the money
Big_Smokey is offline
post #3 of 5 Old 10-01-2013, 04:30 AM
Is this a trick question....LOL. Go with the 6.4, it makes more power for the dollar. It is also more reliable. Since the Ranchero is a 1970, you will never have to worry about emissions. Go for the 6.4 then delete and destroy the competition.
2010 Ford F-250 Super Duty, Lariet 4x4, Crew Cab Short Bed, loaded with every option...and more
turbo kidd is offline
post #4 of 5 Old 10-01-2013, 04:40 AM
6.4 will be faster
6.0 will be cheaper
Moto2four is offline
post #5 of 5 Old 10-01-2013, 07:37 PM Thread Starter
SPY+'s Avatar
dont know a whole lot about the 6.4 hence my asking
the only problem i have with the 6.4 is it seams to be alot wider then the 460 and believe me its really tight in there
the 6.0 dose not look as wide but it looks tall and i would have to get a custom hood made for sure
SPY+ is offline
