Odd tread wear on a dully - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-30-2013, 09:48 AM Thread Starter
XPLOSIV's Avatar
I'm trying to figure out why my dully tire is wearing oddly. It is the inside rear tire on the left side of the truck. It is balding badly on the outter edge. I've already switched it with the right inside tire and that one did the same thing once placed in the inside left rear position with in 500 miles, so it's not the tire itself. Will add a pic this evening. Waiting for a response from my dealership, but my mechanic has never seen it before.
Any thoughts.
08 F450 CCLB 4.30's
Spartan, Pure Performance Custom 3", Toyo M608Z, MBRP, FloPro, Banks, Volant, Mishimoto, Dieselsite, LineX, Reese 30k
XPLOSIV is offline
post #2 of 5 Old 09-30-2013, 10:14 AM
Teachagmech's Avatar
Quoted: 398 Post(s)
Garage
is there a difference in pressure between the two tires on that corner? sometimes if the one dual has too much pressure it can scuff the tread right off of the other. thats why a lot of OTR trucks have balance hoses for each set of duals
Mike"Bustin' mine to feed yours"
The "Kerosene Queen"
2005 F-250 CCSB FX4 LARIAT 150K blue spring, coolant filter, DC Power alt. and
Teachagmech is offline
post #3 of 5 Old 09-30-2013, 11:17 AM
2nd...
My fronts wear faster but I turn too sharp with she's unloaded.
GSchretter is offline
post #4 of 5 Old 09-30-2013, 01:53 PM
CNYWhiteDually's Avatar
tire pressures.. you have aluminum wheels? one is probably leaking around the bead
loosing pressure over time
CNYWhiteDually is offline
post #5 of 5 Old 09-30-2013, 09:33 PM
Quoted: 398 Post(s)
Garage
It really sounds like your left outside dual has too much pressure. If you want to pinpoint that particular wheel, try putting it on the right side.. If the funky wear follows that tire, you'll find the culprit
Sent from a phone that makes calls too!
