Cat or no Cat - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-28-2013, 09:05 PM Thread Starter
DOHC's Avatar
Cat or no Cat
Hey guys. first time post. Lots of info on this site. Ive done a lot of research and cant find a answer to a few questions. It seems most DPF kits also delete the Catalytic converter. Is the Cat also a issues that needs to be deleted? Is the CAT required to be deleted with the DPF on a DPF delete tune? I know people have said to delete it. I was just wondering if it was a must. I don't race my 6.4 but want to do a DPF/EGR delete and a 200 to 300 HP tune from a Spartan. Mostly want more power for the street, tow and better mpg. Thanks for any help
DOHC is offline
post #2 of 8 Old 09-28-2013, 09:38 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
It's a restriction and since your deleting the dpf anyway, it only makes sense to delete the cat as well.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 8 Old 09-29-2013, 05:31 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
I would just delete it also. Makes install easy when installing all new stuff and not trying to split the dpf. The cat doesn't do much anyways.
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #4 of 8 Old 09-29-2013, 05:51 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Dont you need the cat in area's that get DOT inspected?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 8 Old 09-29-2013, 06:40 AM
Big_Smokey's Avatar
Quoted: 8 Post(s)
you need the DPF also. Its a diesel and would need to meet EPA standards as well, correct?
Big_Smokey is offline
post #6 of 8 Old 09-30-2013, 11:25 AM
kinnisoj is right.
Step 1. Can I run my truck legally without it in your state.
Step 2. Save it, maybe not today but one day your state might require it. Never say never. Obama won the election twice.
Step 3. Does the smell from old diesel engines bother you or your family members? If so leave it on, if not take it out. In others smell besides performance seems the only other reason for this decision.
Step 4. It is a restriction (better flow lets her go), I'm going to leave my end but remove DPF.
GSchretter is offline
post #7 of 8 Old 09-30-2013, 12:49 PM Thread Starter
DOHC's Avatar
Ok. So the cat is not required to be deleted with the dpf on a dpf delete tune. Thanks guys
DOHC is offline
post #8 of 8 Old 09-30-2013, 01:53 PM
WoodBoy's Avatar
If you plan on running high horsepower tunes you need to delete it and as well as get you an aftermarket downpipe
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
