doing studs what else? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 09-27-2013, 09:47 AM Thread Starter
Just ordered studs and top end gaskets from rudys today what else should I do while cab is up? 2008 f350 130,000 miles ,4" dp back exhaust,s&b,flo pro full egr delete ,sinister coolant filter,mishimoto rad,sct running idp tunes.exhaust is missing all sensors idled high so I'm considering a 5" turbo back kit and adding whichever sensor it's looking for and possibly rudys uppipes if nothing else is wrong when we get into it.
SCTREEGUY is offline
post #2 of 16 Old 09-27-2013, 10:50 AM
rt_hawk's Avatar
Definitely up-pipes, stocks usually only go 100,000k +-45,000miles, then the bellows go out...it's a whole lot easier doing them cab-off...Rudy's seem to be the go to brand...
2008 F250 XLT CCSB- 90k, 5R110W, b&w hide-a-ball, DIY coolant filter, final charge, dieselsite boots, xrt pro, CAI, SGII, egt gauge, DIY egr cooler blocked/bypassed, viper alarm/ remote start, P/S filter
06 VW Jetta TDI- all options, 100k, stock for now...catching up on maintenance...
04 Triumph Thruxton, cr special carbs, TPUSA cams, MAS side-covers, Lossa stubby exhaust, pingel petc*ck, etc...
rt_hawk is offline
post #3 of 16 Old 09-27-2013, 12:04 PM Thread Starter
Does rudys make them without the egr?
post #4 of 16 Old 09-27-2013, 12:32 PM
rt_hawk's Avatar
Yes they do, more expensive but they do sell up-pipes for egr deleted trucks...
rt_hawk is offline
post #5 of 16 Old 09-27-2013, 02:25 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Yes they make them. I have a set.
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #6 of 16 Old 10-01-2013, 02:58 PM Thread Starter
Ordered down pipe and up pipes from rudys today super excited til the heads came off.after cleaning the pistons I noticed a hairline crack in the top of 1 of the pistons.I'm gonna replace them all but what should I put in and is the coating worth it.already pulled the pan and girdle gonna start pushing them out the holes in the morning.is it ok to reuse the rod bolts?
post #7 of 16 Old 10-01-2013, 03:03 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
Man that sucks. I would go with the HD pistons from Rudy's. I'm not sure about the coating.
08 F350 cc/sb 4X4
post #8 of 16 Old 10-01-2013, 03:10 PM Thread Starter
Also the oem gaskets had blue sealant but the 1s that rudys sent have black.I thought these were supposed to be oem.
post #9 of 16 Old 10-01-2013, 03:23 PM
srjd's Avatar
Quoted: 2 Post(s)
Since you have egr delete you can just get rid of the drivers side up pipe all together no need to spend money on a new one. Just drill and tap your blockoff plate for the ebp sensor
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #10 of 16 Old 10-01-2013, 03:27 PM Thread Starter
I'll have to look at it and see if I am understanding you right tomorrow.
