6.4 should I be scared - Ford Powerstroke Diesel Forum
post #1 of 16 Old 09-27-2013, 03:53 AM Thread Starter
jgrassano's Avatar
I have an 08 job 3 6.4 with 78,000!miles my premium car warranty is up in a couple weeks and just wanting some opinions if this truck will still serve me right without a lot of money in repair. I know its hard to predict. I have spartan tuner, dpf delete 4 inch, afe intake. I run rotella t6 and change it every 200 hours along with fuel filters. Is there anything else. Thanks for the input
jgrassano is offline
post #2 of 16 Old 09-27-2013, 04:08 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
6.4 powerstrokes are very reliable... Especially when the emissions equipment is deleted. I'd drive without worry if I were you.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 16 Old 09-27-2013, 05:20 AM
CNYWhiteDually's Avatar
rotella??? seems like motorcraft is the way to go only....
CNYWhiteDually is offline
post #4 of 16 Old 09-27-2013, 05:29 AM
Hunter of Trolls
drewactual's Avatar
Quoted: 58 Post(s)
rotella t6 is good stuff... 'specially in the winter... I'm not aware of any motorcraft branded oil that is any better.
dpf disappearance is a good thing...
at least blocked egr is a good thing...
lift pump by airdog or fass is a good thing...
coolant filter after a swap to elc is a good thing...
cvs mod is a good thing...
allowing your egt's to drop below 300* before killing ignition is a good thing...
oil analysis and swapping oil on prescribed schedule is a good thing...
driving it like you're paying for it is a good thing...
regular servicing and inspection is a good thing (change your own oil, crawl around under and over the truck whilst it drains looking for issues, and that little activity will save you bookoo bucks)...
A bobblehead doll depicting the deity of your flavor on the dash is a good thing... I 'spose.. I like betty boop with a hula personally, so when I accelerate hard enough I get to peek her snatch... I don't know if that is a good thing or not, but it amuses me..
drewactual is offline
post #5 of 16 Old 09-27-2013, 02:20 PM
'086.4LDiEsEl''s Avatar
Quoted: 2 Post(s)
I would drive it like I have with my truck for the past thousands of miles , but that's me and that's been my luck with my great performing truck. It's hard to say if your truck will or will not last forever, just depends how well you take care of it which I suppose you do. I rarely lend out my truck, and I always keep up with the maintenance, the hardest part about owing the truck was the mortgage on it but that part is gone, now I just have the second part to worry about which is the Fuel haha
'086.4LDiEsEl' is offline
post #6 of 16 Old 09-27-2013, 02:24 PM
Quoted: 48 Post(s)
I wouldn't worry much. I'd seek out DPF removal if feasible.
drunk on diesel is offline
post #7 of 16 Old 09-27-2013, 11:50 PM
Quoted: 8 Post(s)
Wow, how long do you wait for your EGTs to cool down? Once mine gets to 375-400 I shut her down. Unless your egt probe is post turbo.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #8 of 16 Old 09-28-2013, 04:44 AM
floorboy's Avatar
I'm not sure I have that kind of time either.
Originally Posted by bjs505 View Post
Of course I'm handy under the hood, I currently own a cummins.
2010 F350 CCLB Cabelas Edition
No Limit cai, Mini Maxx, 5" turbo back Flo Pro, Sinister egr delete, Sinister coolant filter, Cat EC-1, PTP shift solenoid. 20x9 +18 XD Monsters
01' 7.3 CCLB, 6637,wicked wheel G2, HPX, PHP Hydra, MBRP 4" Turbo back, Bellowed uppipes, Stancor gpr, 6.0 cooler, Fpr, Glow shift exhaust, pyro, trans, 203*/billet housing/ Cat EC-1, '07headlights/05' grill, Oh8' gate.
78' F350 "dumpy" old school
floorboy is offline
post #9 of 16 Old 09-28-2013, 10:53 AM
srjd's Avatar
Quoted: 2 Post(s)
My egts cool down to 300 within a min
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #10 of 16 Old 09-28-2013, 03:10 PM
Capt dong's Avatar
Quoted: 5 Post(s)
its not just the 6.4 but any turbocharged engine should be cooled down prior to shutting off which why the turbo timer was invented. takes me 15-30 seconds to get under 300* but i also coast and barely accelerate when in near parking. this is in 90-100*+ heat and humidity.
08 F250 KR
08 F250 XL
Capt dong is offline
