L-shaped truck bed fuel tank - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-26-2013, 05:34 AM Thread Starter
A friend of mine has a L-shape truck bed fuel tank 110 gal he used for gas. He no longer needs it. Can I use it for diesel?
Thanks
Mark
2008 Ford F350 Lariat DRW
All stock
2012 Keystone Avalanche 330re
2007 Harley Davidson Ultra Classic
cmssorrell is offline
post #2 of 6 Old 09-26-2013, 05:52 AM
Oilboy's Avatar
Is it steel or aluminum If it's steel I would get it steam cleaned first and then let it dry good.
steel or aluminum to clean it out, put 5gal of diesel in it and take it for a good drive down a bumpy road. pour diesel out and inspect if for any loose crap in the tank.
After that should be good to go.
Always run a water/ dirt filter after the pump or inline if your going to gravity feed and lock your cap to prevent theft,
Also if you put a pump on it find something that fits in the nozzle hole to prevent dirt and water from getting in and destroying your fuel system
Enjoy the extra fuel range, I wouldn't own a truck without a slip tank.
2011 F-350 lariat
6.7
340,000kms and still going strong
Oilboy is offline
post #3 of 6 Old 09-26-2013, 06:13 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Ive heard that for cleaning,you can throw a box of BB's in their and drive around with a little bit of fuel. I guess they will knock the junk loose.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 6 Old 09-26-2013, 07:19 AM
srjd's Avatar
Quoted: 2 Post(s)
Diesel might be the best cause some tanks don't have a drain and most pumps have a adjustable plastic spout that is slash cut and doesn't always reach the bottom of the tank so there will always be a little bit left in there even when the pump kicks out. So if you use some other chemical to clean it and pump it out some will be left
01/07 Job 1 F350 H&S Tuned. ARP Studs, AFE 4'' straight pipe, EGR delete with elbow, AFE stage 2 CAI, 6'' lift on 37s, 20x12 Fuel Nuts two piece, Sinister coolant filter, CCV Mod, Projector headlights HID kit
srjd is offline
post #5 of 6 Old 09-27-2013, 04:39 AM
muntu's Avatar
I have both...the 100 gal has a pump and the 50 gal is hooked to main tank [diesel].... carrying gas in these tanks in the bed of a truck is illegal [flash point]....if he had gas in there there is no reason to clean it with bb's or chemicals....it would be clean...besides you can tip it to make sure it is empty..no water remaining.
2008 6.4 job3 F250 3:55 gears 10K gvw silver stretchcab 8ft box.timbrens and goosenek hitch.51 gal aux tank.
muntu is offline
post #6 of 6 Old 09-27-2013, 04:01 PM Thread Starter
Thanks for all the helpful responses!!
Mark
All stock
