needed info, California Smog Performance questions - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-24-2013, 08:24 PM Thread Starter
dukcaln's Avatar
Howdy all, been out of the diesel scene for some time but want to purchase an 08 f250 soon. What can you all tell me about performance options and numbers for an 08 that has to remain smog legal. Tuners, intakes and such.
What numbers can be had with a good tuner, intake and smog intact?
What numbers with smog off?
Is there a delete kit that is easy to remove and install every time I have to smog it, and if so which ones?
04.5 LLY DURAMAX. EFI, AIR, FUEL, TRACTION AND MORE! POWERSTROKE SLEEPER SLAYER!!
dukcaln is offline
post #2 of 7 Old 09-25-2013, 04:32 AM
WoodBoy's Avatar
I wouldn't ever put a programmer on a stock 6.4. It will regen more, and usually clog the dpf also. With an Intake, exhaust, and programmer. You can look at 550-570rwhp range. It isn't hard to return to stock with that setup but that's about as far as you would want to go if you have to go back to stock. How often would you have to do this?
2010 CC/SB FX4 Lariat.. Tuned By Eric@IDP and Matt@Gearhead
Thinking about getting rid of the stock 6.7 turbo?
Check this out... and research before buying
WoodBoy is offline
post #3 of 7 Old 09-25-2013, 09:40 AM Thread Starter
dukcaln's Avatar
thanks for the info, I would have to return to stock form, or at least the dpf system every two years. I would just do an exhaust with the dpf delete, CAI and programmer. So returning to stock would be just replacing the delete and programmer. What would that take to do, time and difficulty?
dukcaln is offline
post #4 of 7 Old 09-25-2013, 09:43 AM
bdtribble's Avatar
Basically if the smog tech can see any modifications, it's a fail. This includes not having a CARB approved air box. I have a 6637 intake and he was going to fail me for that, along with a few other things but I ended up being lucky
bdtribble is offline
post #5 of 7 Old 09-25-2013, 10:36 AM
Quoted: 58 Post(s)
I would just clarify that any "emission system" mods will get you a failing grade. They don't care about other mods. They will check for EGR valve, EGR cooler, cat/dpf, if any DTCs are present/check engine light is on, and will do a snap throttle smoke test.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #6 of 7 Old 09-25-2013, 07:36 PM Thread Starter
dukcaln's Avatar
are there any good tuners that use the dpf in place that gets good power. My point of this thread was to see how easy it was to swap exhaust, add a delete and tuner when it was time to smog
dukcaln is offline
post #7 of 7 Old 09-26-2013, 05:49 AM
bdtribble's Avatar
If your looking to do something like that then your best bet is to buy a whole new exhaust and keep the stock one. That way every other year you can swap the stock exhaust back on and go pass smog. I did kind of the same thing on my 2002 for a while then I decided to just take a breaker bar to the dpf
