Trailer Back Up Light Question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 09-23-2013, 05:22 PM Thread Starter
Mustangnut6788's Avatar
Hey guys,
I just bought a used 2013 CornPro car hauler and the previous owner had installed back up lights at the rear of the trailer. The dealer where I bought the trailer had tested everything and stated they worked. They even tested my truck (2008 F350KR CCLB) but there was no power on the center pin.
I have tried to research the net and haven't really found much information. Are these trucks wired up for the back up/reverse lights in the seven way from the factory? Are there any relays or fuses to check? I don't have a manual to verify.
Any information that you guys could add to help shed light on this situation would be appreciated. (pun intended )
Thanks,
Nate
2008 F-350 King Ranch
2 - 91 Mustang's
Mustangnut6788 is offline
post #2 of 3 Old 09-23-2013, 07:45 PM
If your truck had a factory installed trailer connector, I'm sure the backup lights are wired.
Assuming you have a 6.4, there is a fuse, it's #63 in the engine fuse box (the one under the vacuum pump). I don't think there's a relay for trailer back-up lamps.
When I bought my truck there were about 5 fuses blown, mostly for the trailer stuff. Probably partly because the connector had been broken off. It was a little disheartening hooking up a trailer for the first time and having nothing work.
It should be pretty easy to chase down the problem once you look through a manual and see where all the fuses are.
My truck didn't include anything extra, such as the spare tire key or any manuals. I ended up buying a full set of manuals on Ebay so I'd have a paper copy in the truck. It's handy.
If you don't want to buy a paper copy, and even if you do, you can download manuals for free from fordowner.com. There's also a full copy (in PDF form) of the 6.4 workshop manual out there if you dig hard enough. I've come across links to it in forum posts.
B. Adams is offline
post #3 of 3 Old 09-26-2013, 06:18 PM Thread Starter
Thank you!
I went out and checked fuse #63 and sure enough it was blown. Put in a new fuse and presto lights now work. I knew it had to be something simple. I just didn't have any resources to turn to.
2 - 91 Mustang's
