Degas level - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-22-2013, 10:52 AM Thread Starter
ATVJOE's Avatar
Degas level
I am about to leave for a 2400 mile round trip run with my truck. I just finished cleaning the S&B air filter and noticed my coolant level a bit low (maybe an inch) below the cold level line. Is this normal? Can I just add distal led water?
Thanks
2008 F250 SD King Ranch 4X4, H&S Mini DPF delete
Job 2 LB SRW Crew Cab AMP Power Running Boards
ATVJOE is offline
post #2 of 6 Old 09-22-2013, 11:50 AM
Hard to say if you have a problem or not at this point....top it up and keep an eye on it...seeing as how your in TX with no sub zero weather to deal with i would think that a distilled water top up would be fine.
cuda66 is offline
post #3 of 6 Old 09-22-2013, 11:55 AM Thread Starter
ATVJOE's Avatar
Thanks, I drive 100 highway miles daily with Houston temps in the 90's and usually run at 75mph at 199 ECT. Never noticed any leaks or puking from radiator.
ATVJOE is offline
post #4 of 6 Old 09-22-2013, 01:58 PM
Mine sits at 1/2" below bottom line. If I put any more in the rad will leak.
Trouble maker is offline
post #5 of 6 Old 09-22-2013, 02:25 PM Thread Starter
ATVJOE's Avatar
Does it leak when there's pressure in the system? It has been about a year since I added water and never noticed any leaks. I probably was down about the same, an inch below cold level
ATVJOE is offline
post #6 of 6 Old 09-22-2013, 05:23 PM
Nope, only leeks when its cold and the plastic and rad are cooling at 2 different rates. I was worried about it and let it go for a bit then realized it hasn't leaked any.
