Tire question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-21-2013, 08:38 AM Thread Starter
Tire question
I put this in the wheel and tire section and got no responses, so I figured I would try here
Tire question
I've got an 08 f250 fx4 ccsb with dick cepek FC-2 305/55r20. I got into an accident on wet pavement a few weeks ago. In addition to the damage, the back passenger tire is being replaced because of a cut in the lugs. The tires have approx 11,000 miles on them. If I had to guess they're roughy 1/3 worn. Is that enough difference to be concerned with having the new tire on the back with the old tire or should I replace both rears so they're the same height?
pan4905 is offline
post #2 of 2 Old 09-21-2013, 08:51 AM
alaskan155's Avatar
Quoted: 60 Post(s)
if it has a limited slip replace both rear tires, if its open diff it won't matter, if the fronts are good rotate them back and put the new one on the front,
11k shouldn't be bad just measure tread depth on new vs old
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
