Possible transmission issue - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-18-2013, 01:55 PM Thread Starter
Hoping to get some ideas from you guys about an issue that may or not be a problem. I'm not even sure if it has anything to do with the transmission. I have a 2008 F250 with a Mini Max that I run on the mild street setting with S1L shift schedule with the exception of a few times I switched to the easy tunes to see if it still has the problem. Lately I've been noticing when I slow down the truck sounds like its growling or maybe grinding for 1 or 2 seconds then goes away, but it seems that the slower I come to a stop the longer it "grinds" and the faster I stop the shorter the grind. Its like it has a magic spot. It does not do it every time I slow down. It will do it slowing down from any speed. At first I thought it was the brakes but they are good. Next I did a little research but couldn't find anything like my issue but some guys suggested it might be the converter unlocking quickly but that don't explain why it does it say below 20 mph. The only other thing I can think of is that the seal at the back of the transfer case right before the driveshaft was replaced before I put the tuner on and I was wondering if that can be over torqued. I guess I will change the tranny fluid and see if that helps. The truck runs great and has no other problems. Thanks for the ideas.
bkyota is offline
post #2 of 13 Old 09-19-2013, 05:50 PM
Can you go back to bone stock?
When was the last time you had the fluid changed?
Maybe change it and look for metal on the plug.
Hope it's nothing but wondering if you could be having torque converter problems.
Transmissions probably fine but I've heard of problems with the converter.
GSchretter is offline
post #3 of 13 Old 09-20-2013, 03:51 AM
I thought you could only run SEZ on the street tunes......
seafordguy is offline
post #4 of 13 Old 09-20-2013, 05:00 AM Thread Starter
I could return it to stock but I was hoping diagnose the problem without putting all the junk back on it. I have loaded the easy tunes with the nonadjustable trans settings and I don't think it made the noise but honestly I didn't run it long enough to probably find out. Its been about 50,000 since the fluid was changed so that is going to be my next step. I checked the fluid when I started having this issue and other than rust from the dipstick tube, the fluid looked great and didn't smell burnt. The converter would be my guess to. Is there a way to test it?
Seafordguy, the easy tunes have non adjustable trans settings, but I run mine on the Mild set of tunes, the next set up that are adjustable.
bkyota is offline
post #5 of 13 Old 10-22-2013, 06:22 AM
Quoted: 8 Post(s)
The problem you are having/hearing is what I think is called torque converter chatter. It happens because of the lower shift points in the S1L trans file you are using. Basically from what I understand...the gears don't downshift quite soon enough which causes this "grinding" noise that you hear. I did some research on this and only thing I found out is that it doesn't really hurt the truck...it's just an annoyance. If you load the S1M trans file it doesn't do it anymore as gears shift at a higher speed/engine rpm.
tofer is offline
post #6 of 13 Old 10-22-2013, 07:13 AM Thread Starter
Tofer - that sounds about right. I tried the S1M and it didn't seem to do it but I only ran it for a little while because I like the shifting of the S1L. If it is hurting the truck I would obviously not run it though. I wonder if it is common with tuned trucks or just mine. You're right it is annoying!
bkyota is offline
post #7 of 13 Old 10-22-2013, 07:19 AM
Quoted: 8 Post(s)
Ya S1M I found shifted way to hi...From what I found torque convertor chatter doesn't harm anything really, mind you I could be wrong. What I ended up doing is getting the MCC software and lowering the shift points a bit in the S!M file...or you could always raise the shift points in S1L to I guess..same dif. I'm now using gearhead tunes......his trans file is pretty sweet...load based shifting and everything.
tofer is offline
post #8 of 13 Old 10-22-2013, 07:30 AM Thread Starter
I was planning on getting MCC but was gonna hold out a little longer but this might make me bite the bullet and get it. Where did you read up on it? I did a quick search and couldn't find anything. I will probably get gearhead tunes in the future...I haven't heard anything but good reviews from them.
bkyota is offline
post #9 of 13 Old 10-22-2013, 07:49 AM
Quoted: 8 Post(s)
I just read up on the h&s forums.....Gearhead tunes are amazing....little bit better mileage and like I said the trans tunes are the best I have tried so far.
tofer is offline
post #10 of 13 Old 10-22-2013, 02:29 PM Thread Starter
I think I'll be going with gearhead shortly just in case the chatter may be an issue.
bkyota is offline
